  • SN95 4.6L Mustang Tech
Some rear end questions
  • Thread starter Thread starter BlackArtemis
  • Start date Start date Jan 20, 2010
BlackArtemis
Dated 4 Amandas. Nothing special. Got the job done
West Chester, PA
Jan 20, 2010
  • Jan 20, 2010
Ok, so it seems my LSD is going out.
Now I planned on doing gears anyways so it's nothing horrible.
The question comes down to, how far should I go?
I was planning 3.73's and eventually an S-trim.
Would the 28 splin Diff with carbon pack upgrade and 28 spline axles hold at 375-400 hp/tq?
Occasional drag day, but mostly a crusing fun car.
Or should I just go all out and put in a FRPP 31 spline Diff and moiser 31 spline axles as well.
If I just do the rebuild I could afford a clutch install as well.
(I will not install anything drivetrain related myself, I don't have the tools or know-how, so I gotta do it the expensive route )
The clutch is a prereq for my headers btw :/
trinity_gt
3,125
81
99
Canada
Jan 20, 2010
  • Jan 20, 2010
Good combo. 4.10s would also work well with a centri.
Generally, yes.
However, if you bolt slicks to it and pop the clutch at 4000RPM on a prepped track on a good day, YMMV.
Depends on your budget. Building a stronger rear axle, especially if you plan a blower motor and occasional drag racing, makes sense and gives you a fatter safety margin. If money is tight the 28 can live but it has a lower tolerance for shock loads attendant high RPM clutch drops in high-traction conditions. If you stay 28, keep that in mind as you air down your slicks on race day
04DarkShadowGT
474
Fort Wayne, IN
Jan 20, 2010
  • Jan 20, 2010
I guess the question is how much extra is it to go 31 spline with a whole new diff? But if you are going to pay the labor to get it done in the first place I would go ahead and get it done right the first time. Better to have more than you need than to be on the edge of what it can handle.
I have 4.10s in my t-trim equipped 01 GT, but its an auto.
08GTCSTurbo
24
Rockford Illinois
Jan 20, 2010
  • Jan 20, 2010
the price of the diff should be the same from 28 spline to 31 and you can get axles from moser for around $330 that are a direct swap..just need ABS rings for them
SamsStang
28
Colorado Springs, Colorado
Jan 21, 2010
  • Jan 21, 2010
I agree with "04darkshadow" Its good insurance and just a few bucks in difference.
Even though i still have the 28 spline unit in my 99GT w/eaton posi and Richmond 4;10 gears since 01, ive never snapped an axle ran DRs for years and switched to MT/ET streets for the last 2 years w/100 shot. (i was fortunate) I Dont Drag race the car any more cause its my wifes D.D. in the summer and have another toy.
BlackArtemis
West Chester, PA
Jan 23, 2010
  • Jan 23, 2010
The repair vs the replacement question was brought up because I would be able to get the clutch done at the same time. But I have been leaning towards the entire rebuild. After reading a thread called "superchargers for $1500" I have decided that I will go the blower route. (The thread is great, but it will really cost you about $2000 + tune).
Anyways, so I was looking at all of these parts for what I need done. Anything I am missing?
Ford Mustang 3.73 Gears at AmericanMuscle.com - Free Shipping!
(gear size is not 100% decided on, but I don't feel like making the 999999999999999999999th thread about them, so I will be reading others)
http://www.americanmuscle.com/moser...ed Slip Differential w/ Carbon Discs^3^774.97
http://www.americanmuscle.com/ford-...ed Slip Differential w/ Carbon Discs^3^774.97
As stated before. I don't have a ton of tools and I have limited know ho. When it comes to something like drive train I am not going to attempt to save some $ and do it myself. So sadly it's going to cost quite a bit to install and I will have to put off the clutch install for awhile which shoves back the header install (Something I WILL be doing with some friends).
thanks for all the input
L
lang williams
567
cleveland, oh
Jan 23, 2010
  • Jan 23, 2010
if want to save a few bucks an you were planning on rebuilding the diff anyway, get a used f 150 diff. they're 31 spline an the same cost to rebuild.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
Rear end
  • RileyDymond
  • Feb 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
