Some Stupid Problems I NEED to Fix!!!
69Rcode_Mach1
1,473
Salt Lake City, Utah
Well guys I am going out of my mind. First off I have searched for both, first is the turn signals which I have searched for. My fuses are all good so that is not the problem, my hazards work. I have tried checking at the ignition switch, I heard wiggling it may help but I am lost. I am also confused on where the white plastic plate is located that all the other threads spoke of. The second problem is my sound system, the car came with a small system nothing too special. The thing is that the sub and amp work in the trunk, but the speakers in the car do not. Every once in a while the speakers come on for a bit, then go off. It can be from anything from me turning the volume, pushing a button, or hitting a bump, and it will cause the speakers in the car to play, or stop playing. Sounds like a loose wire the thing is I don't know where to start. The electronics on my 5.0 are new to me, and after looking there is a lot more than in my Mach 1. So I am trying to avoid thinking about it too much. Any help will be appreciated though.
The turn signal flasher is separate from the hazard flasher on fox body Mustangs. Finding it is an easter egg hunt. Some flashers are on the back side of the fuse panel, some are behind the radio, others are near the glove box.
