Well with spring just a few weeks away (yeah right sorry...) I am looking at replacing my rack...as of late it's resembles a fountain more than a steering rack, and I have some questions regarding install and maintaining alignment. Now first question is: with the replacement rack and Tie rods (trw brand), will the overall dimensions (ie overall total length end to end) be identical to the present rack installed in the car..provided the lock to lock ratio is the same?
Second: by measuring the distance from tie rod end to end with rack on the car wouldn't the alignment remain identical if the overal measurement of the new rack and tie rods were the same distance?
Third: if the distances are not identical could I not take a measurement from the distance across the inner lip of the front wheel from side to side and use that as a guide line for accuracy?
I basically hate the idea of bringing my car into a shop for most any reason when I can correct or perform the task myself. Take a read of my questions and correct or add anything you can think of.
D.
D.
