Somebody help! 1991 lx 5.0
  • Thread starter Thread starter Mike Dawg
  • Start date Start date Aug 25, 2006
M
Mike Dawg
18
  • Aug 25, 2006
I recently bought this L.X 5.0 it had a blown motor and since then Ive changed the motor and havent been able to get it to run right .
whats happenig is .. it has NO power at all ive checked the compression its @150 and all cylinders are the same . when its idling I can feel that only 3,4, 5and 7 on the exhaust header are hot the other ones are warm. So I pulled the plugs on those that were only warm and they were all wet so im guessing that there getting gas and apparently not firing but when I pull the wire and hold it close to the plug I can see spark. So If im correct compression , fuel and spark make explosion right? Ive put a timing light on it and 10deg. BTC is where I set it . Im so confused and been working on it for two weeks !! any opinion would be great thanks . mike
bullitstang1313
713
Indianapolis / Columbus, Indiana
Aug 25, 2006
  • Aug 25, 2006
Double check your firing order. For the 5.0 H.O. its 1-3-7-2-6-5-4-8 and for non H.O's its 1-5-4-2-6-3-7-8. Might double check this, its messed me up before.
M
Mike Dawg
18
  • Aug 25, 2006
thanxs but already tried it . Any other suggestions?
blkcobra50
209
  • Aug 25, 2006
4 faulty plugs is odd but did you try some new plugs on those cylinders? what are the plugs gapped to?
M
Mike Dawg
18
  • Aug 25, 2006
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 25, 2006
  • Aug 25, 2006
You can have spark at the wire and no spark at the plug. It takes more voltage to jump the spark plug gap when ther is pressure inside the cylinder.
1.) Ohm out the spark plug wires. Each wire should be about 2000 ohms per foot of lenght in resistance. A 2 foot wire would be 4000 ohms, a 3 foot wire should be 6000 ohms. Less resistance is good, some wires are very low resistance.
2.) If the wires check out good, pull the cap and look for tracks and carbon streaks. Replace the cap if you find any.
3.) If the cap and wires check out good, swap the spark plugs from the hot cylinders to the warm ones. If the warm cylinders run hot after that, the plugs are bad.
4.) If the hot cylinders don’t move, the injectors are suspect. Get a noid light from your local auto parts store. Noid lights are used to check injector wiring to see if the injectors are firing.
or a better picture…
Connect the noid light to the injector for the warm cylinder, & try to start the car. If the injector wiring/computer is good, the light will flash. No flash or the noid light is always on, the wiring or computer is bad. The computers seldom fail, so the wiring is the most likely problem in this case.
M
Mike Dawg
18
  • Aug 25, 2006
Thanxs ill try that and let u know .hey wouldnt the plugs being wet be a sign of it getting gas?
M
Mike Dawg
18
  • Aug 25, 2006
I went ahead and changed plugs and now the plugs that were only warm are now hot and the hot ones are warm !!! Im so lost anymore ideas anyone?
thanxs for every opinion .
N
natestang5.0
60
  • Aug 25, 2006
does the car idle really rough or does it idle normally?
M
Mike Dawg
18
#10
  • Aug 25, 2006
  • #10
rough , and when its cold it runs better then when it warms up
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • dan50
  • Jul 18, 2026
dan50
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
