somebody please help
  • Thread starter Thread starter Graydon5oh
  • Start date Start date Feb 24, 2006
Graydon5oh
215
ARKANSAS
Feb 24, 2006
  • Feb 24, 2006
ok this is about to drive me crazy. The car wont get over 3900 rpm and it start studdering when it gets there. iv checked for vacume leaks on the upper and lower intake. I have even taken it off and re torked it with new gaskets, and checked it for leaks again. i have replaced the map sensor the tps sensior. the firing order and timing is correct. ohh and its a 86 and the motor came out of my 87 which it was running fine in when i took it out. also the 86 didnt have this problem with the old motor.
HISSIN50
34
129
Feb 24, 2006
  • Feb 24, 2006
Do you run a TFI ignition? I dont know snot about duraspark or whatever came before TFI, hence my asking.
I would start with code retrieval.
If you have a TFI set-up, it sounds kinda like a bad TFI, which can be bench tested. Coil is also possible. Could be fuel related too. Plat plugs can cause issues at 4K also.
Well, I am glad to see that I narrowed that down nicely. (that was a joke).
Good luck.
Graydon5oh
215
ARKANSAS
Feb 24, 2006
  • Feb 24, 2006
tfi is new i forgot to mention that and i plugs and wires are new the coil isnt that old but i guess i could try that, but keep things coming
Graydon5oh
215
ARKANSAS
Feb 25, 2006
  • Feb 25, 2006
anybody else got any ideas anything may help
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
