  • SN95 4.6L Mustang Tech
Something very wrong
  • Thread starter Thread starter Totalness
  • Start date Start date Jul 6, 2005
T
Totalness
27
Knoxville, TN
Jul 6, 2005
  • Jul 6, 2005
I have a 98 GT and today it started to act up. It is rough to start like the battery is dying. I went to Advanced Auto and they ran tests on the battery and the alternator, and everything checked out ok. However, while i am driving or sitting at a stop light, the car will shut itself off for a sec or two and sputter back to life. The same thing happens while i am accelerating, and also while i am driving the radio and electronics will go out for a sec but the car still runs.And the only time the check engine light comes on is when it stalls, but right when the car comes back on the light goes off and the car does not store any of the codes. any help is appreciated
Thanks
KronicRacer
502
puttering around Ft Lauderdale, FL
Jul 6, 2005
  • Jul 6, 2005
could be that the starter is going bad. have you had problems starting it?
I
inferno9898
249
Jul 6, 2005
  • Jul 6, 2005
are the connections to the battery clean and secure?
R
Rev Maynard
29
PA
Jul 6, 2005
  • Jul 6, 2005
Is the car hard to to start or does it just die intermittenly? How about if you just start and idle? Does it hunt for idle?
Does the car run fine when you get on it or does it stumble?
It could just be another IAC or something as simple as loose gound,vac leak, or dirty MAF. Needs more details man..
MyEarsHurt
918
  • Jul 6, 2005
Hard to say, check vac lines, check batt ground like Maynard said. Mine was doing this for a while, but I was throwing a code, a bad o2 sensor. Replaced that, and its been fine since.
T
Totalness
27
Knoxville, TN
Jul 6, 2005
  • Jul 6, 2005
the car starts a little ruff but it starts nonetheless. it idls fine and when i go at low speed its ok. but if i go for WOT then it stumbles bad its kinda like when you have a plug foul out but the engine shuts down then comes back to life. i cheack the vac lines everything fine there.
I was thinking maybe my Accel coils or something like that.
Comments?
U
UhadMEatGT
117
  • Jul 7, 2005
Did you check your belt to make sure it isnt slipping? Check your coils, wires, etc.
And check your cables.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
