sound killer
  • Thread starter Thread starter spade33
  • Start date Start date Feb 21, 2007
spade33
198
Tempe, Arizona
Feb 21, 2007
  • Feb 21, 2007
what is the best sound deadiner and heat resistor for the money on the market? i know there is dynamat and i have seen a few others but what would be the best and cheapest thanks for the advice
suki243
662
Southern California
Feb 21, 2007
  • Feb 21, 2007
Umm, it is more complicated than you think, pm me and i'll give you a link to another forum's discussion. It was between me and them they know a lot and help greatly.
It depends what your goals are, and how much you are willing to pay.
Rough estimates,
Eliminating basic engine and road noise will set you bak around 150ish
Making your car sound as quiet as a bmw or a benz goes to 650 to 1k
1966conv
220
  • Feb 21, 2007
Why not post it so everybody can see it?
302 coupe
1,952
Macon, Ga.
Feb 21, 2007
  • Feb 21, 2007
its easier to just focus on making the good sounds louder, LOL.
On a side note, I picked up some stuff called "peal and seal" from Lowe's, its some sort of self adhesive heavy rubber with a aluminum foil type backing on it, pretty much like Dynamat or whatever, but 90% cheaper, I put it on the roof and inside the doors of my 65 F100, and it helped a bunch. I think the stuff was originally made as a gutter liner, or to patch metal roofs of something. Don't think for a second that Dynamat, for all the hype, is a 'new' special product for sound deadening.
0to100to0
100
  • Feb 21, 2007
they have something very similar at some carpet and foam places. i got some for my first car that was a foil lined enduralator..... like particle board (but carpet) and it was very very very cheap and worked well.........
matt
spade33
198
Tempe, Arizona
Feb 21, 2007
  • Feb 21, 2007
i like the idea of making the right sounds louder haha thats what my 89 is like right now not TOO loud but just perfect for me!
CochinoFilipino
171
CA
Feb 21, 2007
  • Feb 21, 2007
This may interest you:
Thttp://www.sounddeadenershowdown.com/
suki243
662
Southern California
Feb 21, 2007
  • Feb 21, 2007
Because some forums get mad when you post links to other forums, but if it doesn't matter I suggest going over to secondskinaudio.com, their forums are dedicated to only sound deadner, the forum you want to look at is the product selection section, my own thread is there and so is bad68coupes.
Just relaying info, they don't suggest using peel and seal becuase it has poor adhesion qualities.
302 coupe
1,952
Macon, Ga.
Feb 22, 2007
  • Feb 22, 2007
3 years so far for my 'peel and seal" in Georgia heat and humidity. I don't think I could take it off if I tried. My prep consisted of spraying the surface with windex and drying it with a paper towel.
suki243
662
Southern California
Feb 22, 2007
#10
  • Feb 22, 2007
  • #10
thats what the told me
70dvr
46
Brandon, Florida
Feb 22, 2007
#11
  • Feb 22, 2007
  • #11
Used this in my trunk. Made a big diff. Got at at Lowes. I overlapped it 50%. Might be the same as Peal and Seal.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
