  • 1994 - 1995 Specific Tech
sound like a stator problem?
  • Thread starter Thread starter BlackVert
  • Start date Start date Nov 10, 2004
BlackVert
5,589
9
98
Bethesda, MD
Nov 10, 2004
  • Nov 10, 2004
Car sometimes cranks up to 15 seconds before starting.
Runs fine until warmed up.
Once warmed up, hesitates and stumbles upon acceleration. Seems to get worse the longer the car runs.
The more i read, the more it sounds like the stator is going bad, but the car has not died on me out of the blue (at least not yet) like other people have described when their stator has gone bad.
What are the symptoms of a TFI module going bad?
I have checked and replaced (or found to be good):
Fuel pressure regulator
Distributor cap/rotor
fuel pump
mass air meter
TrueBlue95GT
966
Connecticut
Nov 10, 2004
  • Nov 10, 2004
I'm having the same problem, so I'm interested in an answer. Mine feels like its something wrong with one of the sensors in closed loop, though, because whenever I turn off the car and turn it back on, the missing stops for a while.
BlackVert
5,589
9
98
Bethesda, MD
Nov 12, 2004
  • Nov 12, 2004
not the stator, i had it replaced yesterday.
here's the other thread that i started about it ...
http://forums.stangnet.com/showthread.php?t=512141
Jo_885o
422
Clint. Twp, Michigan
Nov 12, 2004
  • Nov 12, 2004
Maybe its me but what the hell is a STATOR? Starter maybe
red94fiveo
1,269
Wichita, KS
Nov 12, 2004
  • Nov 12, 2004
The stator is also known as the pagnetic pickup and is housed inside the distributor. Here is a link to a much more detailed description. I had rotating assmebly in my dizzy go bad a couple months ago, and it was rubbing against the stator when the dizzy spun. As a result the car just died one day at about 30 mph.
http://www.corral.net/forums/showthread.php?t=542627&highlight=stator
About the problem, I would check the TFI coil if you've elinated the stator. I have a extra one I would let go of. I'll PM you.
HISSIN50
34
129
Nov 12, 2004
  • Nov 12, 2004
stator is also called the PIP (profile ignition pick up, IIRC).
BlackVert
5,589
9
98
Bethesda, MD
Nov 12, 2004
  • Nov 12, 2004
it is also called the Hall Effect Sensor
J
jwater7
104
  • Nov 13, 2004
I had mine go out a few weeks ago. My symptoms were:
After the engine warmed up, it would stall.
Or, after the engine warmed up and then I shut it off, it wouldn't start.
If I left it alone for a while, it would usually start up again...but then the cycle would continue.
I paid something like 50 bucks for it, all it is, is just a "rotor position sensor" but technically, when a magnetic field is applied to a semiconductor, it will produce a small voltage (which in turn gets sent to the ignition module for timing purposes, I think).
Hope this helps,
jwater7
rude_life
372
  • Jul 28, 2005
It has been said that when you lose the Stator, you also lose the injector pulsing. OK, so what exactly happens when you lose injector pulsing and in what way in the terms of symptoms might one experience that has lost injector pulsing due to a PIP Module (Stator) on the fritz?
BlackVert
5,589
9
98
Bethesda, MD
Jul 28, 2005
#10
  • Jul 28, 2005
  • #10
HISSIN50
34
129
Jul 29, 2005
#11
  • Jul 29, 2005
  • #11
I think I am the one who said that.
The PIP tells the puter base spark timing and injector timing. The TFI only modulates spark advance. So this is a means to differentiate whether a PIP or TFI went south (it is REAL easy to fry a PIP with a DMM doing Ohm testing).
A noid light (3 bucks at the parts store) will tell one if they have injector firing (the puter sends a ground pulse to the injectors, not 12 volts, to energize injectors).
If one loses TFI or PIP altogether, the car cranks but wont start.
rude_life
372
#12
  • Jul 29, 2005
  • #12
Well lately it has been cranking over a whole lot before firing up. Never did that before, just used to fire right up.
rude_life
372
#13
  • Jul 29, 2005
  • #13
HISSIN50
34
129
Jul 29, 2005
#14
  • Jul 29, 2005
  • #14
If you have a fuel pressure gauge Kris, note the values you get before priming and after priming.
Or, just cycle the ignition key a few times before trying to start the car for the first time. This will give the pump some extra prime time and may be all that the issue is (not that it will be, but it certainly is worth a shot).
Good luck.
rude_life
372
#15
  • Jul 29, 2005
  • #15
Well i always allow the pump at least 10 seconds to prime before I crank, but my pump is only 2 months old. Also i have replaced the fuel filter recently. The issue with the cranking alot before starting just started. I must check my fuel pressure.
Zero Signal
2,633
Tucson, AZ
Jul 29, 2005
#16
  • Jul 29, 2005
  • #16
The pump shuts off at 3 seconds anyway.
Anyhoo, I had the same problem, it turned out to be a puddle in the distributor from when I went through a foot and a half of water at 30mph
rude_life
372
#17
  • Jul 29, 2005
  • #17
I just had my dizzy halfway apart yesterday and didnt see anything like that. I have replaced all of the usual suspects though. Fuel pump, fuel filter, fuel pressure regulator, 02 sensors, MAF sensor, Air Charge Temp sensor, Coolant Temp Sensor, New Plugs and wires with correct gapping, new cap and rotor, new coil, adjusted timing, always run 91 octane. Damn car
HISSIN50
34
129
Jul 29, 2005
#18
  • Jul 29, 2005
  • #18
But (unless I am confusing the fox with the SN, which I dont think I am because they both operate the same) during cranking, the pump resumes priming. So if one has to crank for a prolonged period, it can be simply because the system is building pressure. Cycling the key several times before attempting to start the car helps diagnose this.
Good luck.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Dies at start up, mild surge
  • Dontknowchit
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2025
