- Jul 31, 2017
- 284
- 89
- 48
I have been reading through the surging Idle checklist. Last night I did a smoke test and was able to attack a very minor vac leak. same symptoms today, thinking it is the IAB/IAC but i know that is a easy blame. symptoms are:
-Cold start, engine dies but not right away, sometimes twice. (checklist says this is big indicator)
-Minor surge. Does not get out of control like I have had before but slowly bounces 50-100 RPM, enough to hear but exteremly mild.
-Pulled IAC plug while running warmed up and nothing happened, no real change
-Idle is set kinda high~750 as that is where it seems to want to be the smoothest. (it's got a vortech, TB, and manifold upgrade)
-Idle seems to get a bit better after fully warm but minor surge never truly goes totally away.
-Planning on puling and cleaning after work but this is a recent replacement. Reasonable to clean it and then shoot a little WD40 in there?
-Going to try the Dx that is in the surging idle checklist but not sure if I understand it correctly.
-I believe my TFI is rather old, while that is not on the checklist, could this be Symptom of a bad TFI? Have been hesitant to replace preventitivley as I know its hit and miss even with motorcraft branded replacements.
