spark gap causing 94gt to lean???
  • Thread starter Thread starter beaver2489
  • Start date Start date May 4, 2004
beaver2489
503
st. joseph missouri
May 4, 2004
  • May 4, 2004
My buddy has a '94 gt with 302 shortblock, TF twisted wedge heads, kenne bell custom cam, 1.6rr, TF track heat intake.....he has had this leaning out problem at high rpms since he got the car. It had the problem with the stock 302 setup in other words. Hes tried swaping computers, setting his timing and fuel pressure, and nothing works. He has to have his fuel pressure over 50 to not lean out up top, which makes for a rich low end. He gaps his spark plugs at .045. Could that be his problem? I know after '91 the coil output was raced and the spark plug gaps were widened. So in his '94 would his .045 gapping be causing his problem? His cam is installed straight up, base timing is 14* adv. and has tried 10*adv., and fuel pressure hes tried stock to 55. Thanks
BlueDevil95
184
Elkton, MD.
May 4, 2004
  • May 4, 2004
First off, what size injectors is he running? He should have 24's with that setup. It could be a fuel pump going bad, clogged fuel filter or a mass air issue. Spark gap should not have that big of an effect here. I run anywhere from .35 on the bottle to .60 on the motor and no leaning out problems on pretty much the same setup. check the easy stuff first, vacuum leaks, change the fuel filter, etc.
beaver2489
503
st. joseph missouri
May 4, 2004
  • May 4, 2004
he has a new 255 walbro fuel pump and filter, 75mm Pro-M meter with #24 injectors. and he has checked for vaccum leaks...but he could check again, thanks
JJFIVEOH
263
Boca Raton, FL
May 4, 2004
  • May 4, 2004
Is he running an MSD? I have a 6AL and found that my ETs are best at .068 gap. This wouldn't be the reason for it to run lean though.
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
