  • 1994 - 1995 Specific Tech
Spark jumping
  • Thread starter Thread starter 1slow95
  • Start date Start date Apr 27, 2007
1 of 2 Next Last
1slow95
1,797
ohio
Apr 27, 2007
  • Apr 27, 2007
I have a bit of an erratic idle, the car's been missing while cruising and occasionally at very high rpm's(5800 or so). So I installed a new coil tonight and I was also checking the spark plugs in the dark to see if any of them were jumping. I noticed a few were on the pass side, one of them really bad apparently because the boot was white. I fixed that side by removing my heat shields from the plug wires....Now I just hope the boots don't melt or catch on fire!
I'm not sure what to do about the driver side...One wire is touching the dipstick tube and arcing to it occasionally, so I just need to find a way to keep the two separated. Then I noticed two of the plugs had a circular blue glow around them. I didn't have a light to see exactly where it was coming from, but I'm guessing it's around the threads. I tried to tighten one of them, but it was still pretty tight. My next thought was maybe I should remove the washer from the plug?
I just did a quick search on here and somebody mentioned the plug gap could be too large. I have it set to .60 I think, is that too much? I'm using Autolite AR3923(sidegapped) and Taylor 409 10.4mm wires. I also have a MSD dizzy, Crane Hi-6 ignition, and just installed MSD coil.
chaos254
467
NJ
Apr 28, 2007
  • Apr 28, 2007
stock gap is .052-.056. If your wires are arching its probably time to get another set.
go-stang5.0
2,244
Glenview,Il
Apr 28, 2007
  • Apr 28, 2007
I've had that problem from the start w/ my MSD wires. Although I havent noticed any hesitation etc. I tried regapped my plugs from .065 to .05 and that didn't help. I havent seen any problems from it so I've been running it for like a year now. However, I am running a completely stock cpu with the motor in my sig and I have some funky drivability issues...the wires could be adding to the problem...but i dont know. I think I am gonna get some livewires on my next tune up and go from there.
HISSIN50
34
129
Apr 28, 2007
  • Apr 28, 2007
Hey Mike,
Your name came up earlier when Will and I were talkin a little about engines.
I agree with you and the other guys - the wires are likely where the issue's at. I have used fuel line (with a lengthwise slit cut into it) to sheath plug wires. While I do this permanently (I dont have a showcar) you could do this just for diagnostics. If you can sheathe your wires like this and fix the issue, you know it was only a wire issue and can know that fresh wires are a real fix. If not, it won't be money wasted on new wires.
I won't mention a way of insulating wires at the boots if arcing to metal is occuring (it involves using the what you have available. I once cutoff the heel of an old sandal and used it as insulation. ).
I would not think your gap is too large (it sounds like something degraded [like wires] and caused the issue since the car ran well before. Ergo the ignition can handle the gap you have). But if you do tighten the gap up and things get better, that's a fix of sorts. It's probably not the one you want to pursue though.
Random ramblings.
Good luck.
1slow95
1,797
ohio
Apr 28, 2007
  • Apr 28, 2007
I bought these wires to try to fix my idle problem. They're only a year old with 1000-1500 miles on them.
I think I fixed most of the problem by removing these...They were touching the plug itself, and it looks like they might be a good conductor.
The only other arcing I noticed from the wires was to the dipstick tube. The glowing plugs are what I'm mainly concerned with. I've got an extra set of spark plugs, should I try replacing those two and see what happens?
HISSIN50
34
129
Apr 28, 2007
  • Apr 28, 2007
Glad to hear you're getting it whipped Mike.
If you just have cheapo plugs in there, I would swap the glowing ones out just for the sake of doing so. That glowing thread issue is a weird one (I'd have expected broken ceramic on a plug to make that happen).
Good luck bud.
1slow95
1,797
ohio
Apr 30, 2007
  • Apr 30, 2007
I took the car out for a short trip last night and driveability was much much better, but it's still missing at high rpm's. That problem started when I installed new plugs gapped at .045(old one's were .055). I then put the old plugs back in gapped at .060 but it's still doing it. Should I change the gap back to stock? Or should I try some new plug wires?
BTW, I didn't get a chance to work on the spark problem over the weekend. I was too busy installing sfc's and lca's. I need a day or two break from the car, then I'll get back to working on it.
HISSIN50
34
129
Apr 30, 2007
  • Apr 30, 2007
So it runs better with a larger plug gap? That's weird.
I really wouldn't know which way to guess as to what to swap out (I'd play with plug gaps because it's cheaper than wires, but if one surmises wires are needed anyhow...............).....
I'm not sure Mike but I can atleast get you a bump.
Good luck bud.
Pokageek
2,767
MA, USA
Apr 30, 2007
  • Apr 30, 2007
I have the screamin demon coil and on my 306 have it gapped to .060. From memory, the higher the gap, the better the higher RPM performance....provided you have the juice for it..I am not sure what I an going to gap the 408 plugs to.
I do have one semi melted plg wire (cosmetic but deep). Does anyone have any recommendations for protective boots?
1slow95
1,797
ohio
May 9, 2007
#10
  • May 9, 2007
  • #10
I don't have time so I'll just post a quick question for now...Should the coil light up at night? I see it lighting up blue on both sides of the coil.
More later...
HISSIN50
34
129
May 9, 2007
#11
  • May 9, 2007
  • #11
More later...
Some aftermarket coils do light up. I personally don't *like* to see it happen but as long as it's just an inductance thing (and not power flowing through a ground path), I would not sweat it too much.
1slow95
1,797
ohio
May 9, 2007
#12
  • May 9, 2007
  • #12
That's good, I guess. Anyways, let me start this thread over since I think I confused you guys earlier....I'm good at that!
Everything I said I've done in this thread was done before I started the thread. I noticed sparks jumping pretty bad so I removed those plug wire heat shields. At the same time, I installed an MSD coil. That's when I started this thread.
I've had an occasional erratic idle almost since I got the new engine running. I didn't worry about it for a while because I thought a tune would fix it. I installed new wires(the ones I currently have), Crane Hi-6 ignition box, new O2's, and new plugs right before having it tuned. It ran great for a while except for the idle thing, so I tried to fix that. Gapped the plugs to .044 per Crane's instruction manual. It ran a little smoother, but that's when my 5800rpm miss started and I lost 15rwhp on the dyno(different dyno, different days...could have been partly weather related). So I put my old plugs back in gapped at .054ish(not .060) and the power was back but it's still missing.
Back to the present situation. After I installed the coil/removed heat shields, I took the car out and it ran perfect except for that miss at 5800. I had it out again a few days later with the same results. Then Saturday I went to a car show and it's back to running like crap. I read in another thread that the TFI is grounded through the frame, and I realized that I just zip tied mine on 2 years ago, so last night I got it mounted solidly on the frame. I still have the same problem! Could my TFI be bad? I tried switching back to the stock tune, and bypassing the Crane box but it still has a horrible miss while cruising plus the miss at 5800.
Could a jumping spark cause these problems? I noticed and OCCASIONAL spark to the dipstick tube and valve cover, but it's not constant like it was before. Also I noticed ALL the spark plugs are "glowing". I don't know if that's a problem, or if it's like the coil thing where it's not really a good thing but it's not a problem...
Also something I just remembered. At one point when I was changing plugs last summer, at least 2 of my plug wires had the metal pull partway out of the plug end. I figure that's part of the problem, but I hate to buy new wires since I paid almost $100 for these and they have less than 1000 miles on them.
Summary: Horrible miss while cruising, it's fine while accelerating until 5800rpm when it's pops/misses. Runs great one day and crap the next. Bad distributor? plug wires? plugs? TFI? Something else? Help!!!
:SNSign:
Sorry for the long post.
1slow95
1,797
ohio
May 10, 2007
#13
  • May 10, 2007
  • #13
Nobody can help me? I've got a good TFI I can "borrow" from my parent's car, I plan on trying that this weekend. I also have an old set of wires I will try in place of the couple one's I'm not sure about if the TFI isn't the problem.
What about the dizzy/pip? First time I started my engine I had a bunch of air in the cooling system and the radiator hose popped off splashing water in the distributor. I don't know if that would have hurt anything or not. Everything but the TFI is new, or was recently new, but I've had a rough idle since I got the engine together and it's been getting worse.
Here's what the idle sounds like, http://www.mustangaddiction.com/movies/miss.wmv. Listen close at the 5-6 second mark. That's what's prompted me to change plugs/wires/coil/etc.
Y
yellow1995Cobra
2,959
Massachusetts
May 10, 2007
#14
  • May 10, 2007
  • #14
These issues deffinatly suck and can really make you pull your hair out.
If you have spark jumping anywhere, i would deff start with changing that wire or plug(if porcelin is broken). Ive had coils that did glow and it wasnt a problem. I cant recall ever seeing any spark plugs glow though.
Those plugs you are using.. They are one stage cooler correct? What made you go with those? And where the hell did you find the autolite AR series plugs? Everywhere ive went they have told me im crazy and theres no such thing lol.
Anyways, backt o your issue. Getting water on the distributer has ALWAYS caused me headaches. It would always cause the car to miss and do crazy things, usually just dieing and not starting back up until it was completely dry. Any spark jump at all WILL cause a miss. In my experiences it can be kind random with plug wires. And when its a plug issue (cracked porcelin) its always there and always at a certain RPM.
Your issue with the metal pulling out of the plug deffinatly sounds suspect as part of the issue. The live wires i bought came with a die-electric grease to put on the tip of the plug prior to putting the wire on to stop that from happening.
I hope you can figure this out man
1slow95
1,797
ohio
May 10, 2007
#15
  • May 10, 2007
  • #15
I don't know which way is cooler, but AFR lists the 3922's as the starting range for the 225 heads. I got the 3923's because, well, I forgot what one's I needed to get. I found the AR plugs at Advance auto like two years ago, but when I checked for replacements last year I couldn't find them on their website.
I don't think cracked porcelain is the problem....It IS always at the same rpm, but it's NOT always there...And it's done it with 2 sets of plugs.
Hmm....You know, it started running like crap again right after I washed the car....And my hood scoop is right above the distributor....That might explain the random missing, but it still misses at 5800 when it's completely dry.
Would there be any long term affects to water in the distributor? Because what I posted before happened 2 years ago when I first fired it up. Since that happened first thing, I can't tell if the dizzy is causing my idle problem or if it's something else.
Thanks for the advice, I've really got to get this fixed. We've been having all this perfect weather and I haven't been able to get the stang for more than a few minutes at a time!
go-stang5.0
2,244
Glenview,Il
May 10, 2007
#16
  • May 10, 2007
  • #16
I have afr 185's and I was told to start with 3924's...I am pretty sure I am running 3923's now as they are 1 step colder...but dont quote me on that. So have you messed with the TFI yet....I am going to be changing my plugs and wires with my upcoming cam swap and will go from there. But I havent found a sloution to my problem either....I'll post up here if I make any discoveries. I just finished finals so I have some free time.
HISSIN50
34
129
May 11, 2007
#17
  • May 11, 2007
  • #17
Mike, given that it happens at cruise and at near redline, I doubt it's the TFI. If it was only at near redline, I'd consider a bad dizzy bushing but that shouldn't affect cruise condidtions.
Like Yellow, the plug wire stuff still has me kinda worried. I'd do shadetree sheathing and insulating to see if you can change the symptoms. If so, you can feel good about wasting money on new wires (I hate buying parts unless I know they're the issue). Really watch separation too - you mght have a cross fire going.
Good luck Mike.
1slow95
1,797
ohio
May 11, 2007
#18
  • May 11, 2007
  • #18
Good luck Mike.
By separation you mean the plugs wires should not be touching each other? I was curious about that, because that's kinda what the idle thing sounds like to me....
HISSIN50
34
129
May 11, 2007
#19
  • May 11, 2007
  • #19
Absolutely, regarding keeping the wires separated (kind of an induction crossfire). The racers in here can tell which two wires in particular are notorious for it (IIRC, there was even a TSB for it on foxes, and I cannot think of why the TSB would not apply to us since we have the same basic components and packaging). I know that Rick91GT knows which two wires are known to crossfire (and Paul and the others probably do too. I never dealt with it so the info went in one ear and out the other).
I think I mentioned before that I've used fuel line to sheathe plug wires for diagnostics. And it does work to help find a crossfire! I'd buy a few feet of fuel line, slit it lengthwise and slide it over the wires where you think there could be an issue. I can think of NO ignition that can permeate a plug wire's insulation and go through the wall of fuel-line to create a short.
It's just something that's real cheap and easy to do - if fixes the issue, you know your wires are bad. With those expensive wires you run, it sucks buying some in hopes that it fixes the issue (but you're much more affluent than I, so it might not be worth your time to hose around with the kind of crap I end up doing. ).
Good luck Mike.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 11, 2007
#20
  • May 11, 2007
  • #20
About that cross fire between the plug wires ...................
I poked around in my notes and saw some talk about #5 & #6
Just something I saved off some forum so I can't say for certain
its even valid but thought I'd pass it along
Grady
1 of 2 Next Last
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
