spark plug gap question
  • Thread starter Thread starter jerry S
  • Start date Start date Jan 14, 2006
jerry S
1,365
52.22N 5.12E
Jan 14, 2006
  • Jan 14, 2006
Is there a general rule on determining the best gap for your plugs? I know I have the correct plugs for my CR (10.5:1) but am ignorant as to the optimal gap. Can somebody who knows give me some tips?
iskwezm
4,159
20
79
Rowland Heights,California
Jan 14, 2006
  • Jan 14, 2006
depends if you have a stock ignition or add on box.Mine used to be at .035 for the nitrous,but i have since closed the gap to .028 for the blower
2nd Mustang
2,488
Southern California
Jan 14, 2006
  • Jan 14, 2006
I have a 302 with 10.5 to 1 compression, mild hydraulic cam, headers, Holley 600, MSD6A, Unilite electronic ignition conversion, etc...... I have my plugs set at .045. It seems to run okay, but then I haven't really looked at them in over 3 years.
jerry S
1,365
52.22N 5.12E
Jan 14, 2006
  • Jan 14, 2006
I have an aftermarket ignition: MSD 6AL with the Pro-Billet distributor.
D
D.Hearne
11,730
south louisiana
Jan 14, 2006
  • Jan 14, 2006
Ditto on mine with electronic ignition-- .045. Works fine. Plugs last well over a year.
Pbum5
515
Minneapolis, MN
Jan 14, 2006
  • Jan 14, 2006
Also have a Unlite and gap at .045 with good results
jerry S
1,365
52.22N 5.12E
Jan 15, 2006
  • Jan 15, 2006
thanks for the replies. What I am wondering is whether there are any criteria for determining the correct gap or is it just trial and error?
D
D.Hearne
11,730
south louisiana
Jan 15, 2006
  • Jan 15, 2006
I just go by what the factory settings are, points gap was around .035, electronic is usually .040-.050. It also depends on how hot a coil you run. Wider gap takes more voltage to get the spark.
jerry S
1,365
52.22N 5.12E
Jan 15, 2006
  • Jan 15, 2006
I should have specified that I have an MSD Blaster 3 coil to go with my MSD HEI distrib and MSD 6AL box. This particular coil puts out 45,000 volts max. Is it a safe bet to split the difference between .040-.050 and gap the plugs at .045 as suggested in this thread?
D
D.Hearne
11,730
south louisiana
Jan 15, 2006
#10
  • Jan 15, 2006
  • #10
With all that firepower, those plugs should fire even with double that The first time I tuned up my 95 E150's 351, I checked the plug gap on the originals as I pulled them. After 80,000 miles, they still fired fine, I just figured it was time. The gap on most was something like .085 But all in all .045 is a good start.
jerry S
1,365
52.22N 5.12E
Jan 16, 2006
#11
  • Jan 16, 2006
  • #11
Thanks everyone. I appreciate the help.:SNSign:
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
