Is there a general rule on determining the best gap for your plugs? I know I have the correct plugs for my CR (10.5:1) but am ignorant as to the optimal gap. Can somebody who knows give me some tips?
I have a 302 with 10.5 to 1 compression, mild hydraulic cam, headers, Holley 600, MSD6A, Unilite electronic ignition conversion, etc...... I have my plugs set at .045. It seems to run okay, but then I haven't really looked at them in over 3 years.
I just go by what the factory settings are, points gap was around .035, electronic is usually .040-.050. It also depends on how hot a coil you run. Wider gap takes more voltage to get the spark.
I should have specified that I have an MSD Blaster 3 coil to go with my MSD HEI distrib and MSD 6AL box. This particular coil puts out 45,000 volts max. Is it a safe bet to split the difference between .040-.050 and gap the plugs at .045 as suggested in this thread?
With all that firepower, those plugs should fire even with double that The first time I tuned up my 95 E150's 351, I checked the plug gap on the originals as I pulled them. After 80,000 miles, they still fired fine, I just figured it was time. The gap on most was something like .085 But all in all .045 is a good start.
