spark plug gap
  • Thread starter Thread starter 5.HO
  • Start date Start date Oct 22, 2006
5.HO
14
NEW JERSEY
Oct 22, 2006
  • Oct 22, 2006
i have been searching and i think i should gap mine to 0.54??
its a 1987 5.0 with bbk shorty's to slp catless x pipe and bbk cold air intake...
HISSIN50
34
129
Oct 22, 2006
  • Oct 22, 2006
Welcome (to Tech anyhow)!
I think you mean 0.054". And that's about where I'd be (I run 'em a little tight at 0.048").
As you've likely read, some 5.0s dont take to plats too well. Most of us run copper.
Good luck.
93gtmustang
525
43
49
Oct 22, 2006
  • Oct 22, 2006
Stock Motor. .054 GAP on Autolite No. 25 plugs. Go to Advanced Auto Parts web site. Just select your vehicle and they give you the proper parts for your vehicle. Hope this helps.
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 22, 2006
  • Oct 22, 2006
what they said
5.HO
14
NEW JERSEY
Oct 23, 2006
  • Oct 23, 2006
thanks a lot guys! new plugs and wires are in! it feels way better. right now it is getting all the brakes redone... it needed em bad
5.HO
14
NEW JERSEY
Oct 23, 2006
  • Oct 23, 2006
got another question... when i had the rear end in the air.......... i spun one tire forward and the other tire went backwards... is this wrong?
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 23, 2006
  • Oct 23, 2006
If the trans is in gear or park they will spin opposite. If it's in nuetral, they should spin together
5.HO
14
NEW JERSEY
Oct 23, 2006
  • Oct 23, 2006
interesting... when i did that test, it was in gear... when i put the car in first gear and reved it and dumped the clutch, i am pretty sure it left only ONE tire mark...
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Oct 23, 2006
  • Oct 23, 2006
Well if it's in gear, you are locking the driveshaft in place so when you spin one tire, the other needs to move the opposite way.
Try it again with the trans in nuetral, and both will spin the same...howver this is not a good way to test if your t-lok is ok. Every open difs will both spin forwards sometimes
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Oct 23, 2006
#10
  • Oct 23, 2006
  • #10
hmm....shouldnt do that for the year and model. it should have a posi rear end. see if you can find a tag on the rear end somewhere and post the numbers that are on it. that way we can tell for sure whats inside
5.HO
14
NEW JERSEY
Oct 23, 2006
#11
  • Oct 23, 2006
  • #11
ok so jack the rear end up and put the trans in neturel and both rear tires should spin forward... ok but im a little confused and i am NOT very mechanicly inclined. but i thought the fox's had posi rear meaning both tires should spin forward when dumping the clutch or doing a burn out no?
5.HO
14
NEW JERSEY
Oct 23, 2006
#12
  • Oct 23, 2006
  • #12
also its an LX NOT a GT.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Oct 23, 2006
#13
  • Oct 23, 2006
  • #13
still should have posi
5.HO
14
NEW JERSEY
Oct 23, 2006
#14
  • Oct 23, 2006
  • #14
can you explain in more detail? if i dont have posi what do i have? any idea why? how can i fix it?? please explain what exactly a posi rear end means
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Oct 23, 2006
#15
  • Oct 23, 2006
  • #15
posi-traction....aka trac-lok. puts power to both wheels as long as one isnt spinning. if you dont have a posi, only one wheel gets power and it just so happens that the one getting all the power is the one that is spinning.
MikeC
240
SLC, UT
Oct 23, 2006
#16
  • Oct 23, 2006
  • #16
You have a limited slip (track lok, posi, etc...) diff with worn out clutch plates, unless someone replaced it with an open diff unit. The plates are slipping allowing only one wheel to spin. Rebuild it with a clutch kit and both wheels should spin evenly.
5.HO
14
NEW JERSEY
Oct 23, 2006
#17
  • Oct 23, 2006
  • #17
how much does that go for?
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
