F fish254 Founding Member Sep 20, 2002 237 0 16 Brooklyn NY Oct 8, 2006 #1 Oct 8, 2006 #1 i runing zex nitrous with a crane ignition HI 6 box digital what should i gap the plugs to???
94CobraPace Founding Member Aug 30, 2000 907 1 0 Houston, Tx. Oct 9, 2006 #3 Oct 9, 2006 #3 Yep, .035" & 1 heat range colder plug.
F fish254 Founding Member Sep 20, 2002 237 0 16 Brooklyn NY Oct 10, 2006 #4 Oct 10, 2006 #4 even with the crane ignition thats the right gaping??
Swarzkopf Member Sep 23, 2004 973 0 16 Pittsburgh Oct 10, 2006 #5 Oct 10, 2006 #5 Eh.. 75 shot- gap at .040 100 or 125 shot- gap at .035 You will notice less power n/a with a smaller gap, hence why I'd run .040 if you're only using a 75 shot.
94mustangcobra Member Sep 29, 2006 126 0 16 Valdosta, GA Oct 10, 2006 #6 Oct 10, 2006 #6 i've been running AR-94s (two steps colder) gapped .035, zex 125 dry shot.
Methodical 15 Year Member Dec 1, 2003 1,192 11 59 Clinton, MD Oct 11, 2006 #7 Oct 11, 2006 #7 Why can't you run the stock gap with nitrous? Just curious because I plan to do nitrous and trying to learn some before diving in.
94mustangcobra Member Sep 29, 2006 126 0 16 Valdosta, GA Oct 11, 2006 #8 Oct 11, 2006 #8 blows the flame out when you start spraying.
69clark Founding Member Sep 25, 2002 731 7 18 Ravena, NY Oct 11, 2006 #9 Oct 11, 2006 #9 I ran into the same problem several years back. I had the Crane ignition as well and still had to gap down to .035
