spark plug question
Yes. Run a cylinder balance test to quickly narrow it down.
Then examine the plug as Fred noted. If the gap is way out of spec, inspect the wire (often the wire gets taken-out with large plug gaps because electricity finds a lesser path of resistance [i.e. through the wire's boot]).
Good luck.
no i did not replace the plug after the head gasket was replaced. i have the car stored, and was just running it to have the oil wash out the engine, and do oil changes.
If you only get the vibration at high rpms and it seems to idle fine I would look at it being an engine balance issue. More of a harmonic balancer or internal damage type issue. Plugs being fouled would give you a miss. This would be noticeable at idle. Just do an engine balance test first to see if the computer notices 1 cylinder not performing the same as the others. There is no sense in going to buy new plugs when you don't know that they are bad.
