  • SN95 4.6L Mustang Tech
Spark Plug Question
  • Thread starter Thread starter flstang65
  • Start date Start date Apr 7, 2009
flstang65
1,484
135
94
SE Georgia
Apr 7, 2009
  • Apr 7, 2009
Anyone ever use the Bosch Platinum +4 plugs?
Killa
1,006
56
49
Apr 7, 2009
  • Apr 7, 2009
. NGK, autolite, motorcraft. that it.
flstang65
1,484
135
94
SE Georgia
Apr 7, 2009
  • Apr 7, 2009
Lol, I was just asking. I'm going with Autolite double platinums.
Killa
1,006
56
49
Apr 7, 2009
  • Apr 7, 2009
still
Copper is what you need
flstang65
1,484
135
94
SE Georgia
Apr 7, 2009
  • Apr 7, 2009
how so if the oem plugs are platinum? just curious.
M
Midnight2V
224
Oklahoma
Apr 8, 2009
  • Apr 8, 2009
Platinum plugs are used as oem because they last longer than copper plugs. This gives them better long term emissions, and allows for a much greater period between plug replacement. You should replace copper plugs at least every two years, while platinums are usually rated for at least 60K miles.
As far as performance is concerned, copper is a superior conductor and will yield better performance (however slight it may be). More important than the electrode metal is the amount of gap you can/should use in your application.
RedDaemon
3,470
9
108
Atlanta, GA
Apr 8, 2009
  • Apr 8, 2009
how many miles are on the car?
i changed my plugs and COPs at ~85k. i used the motorcraft platnium plug and theyre working great so far
for all intents, my car is stock. theres no gain in using copper plugs in my car. especially since platnium reduces the risk of spark plug blow out since i dont have to change them as often.
you dont need to worry about blow outs since you have the longer thread head design.
streethorse
1,042
Dallas Texas
Apr 8, 2009
  • Apr 8, 2009
I tried the Bosch regular platinum and they seemed fine at first, but after
about 10k miles my car started getting slow to start, I had a thread asking
why my car was acting like that, but didnt get an answer. Any way I decided
to go back to stock Motocraft platinum, and Boom the problem was instantly
solved. Never again will I run Bosch in a Mustang.
Put a magnet on the tip of a Bosch plug and then a Motorcraft. The magnet
will barely stick to the Bosch but will grab the Motorcraft like crazy. They use
some kind of F__'ed up alloy.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 8, 2009
  • Apr 8, 2009
i'm running NGK TR6's in mine
SFC.Kill
55
Parker Ford, PA
Apr 8, 2009
#10
  • Apr 8, 2009
  • #10
Kept getting misfires with bosch, went back to autolites.
flstang65
1,484
135
94
SE Georgia
Apr 9, 2009
#11
  • Apr 9, 2009
  • #11
I'm going to go with the Autolites. I have always had good luck with them in all of my Fords. I had 3 COP's go bad 2 weeks ago. I only have 59,xxx miles on the car. I have had it for a year and a half (bought with 46,000 miles). The previous owner used and abused the dog crap out of this car before I got a hold of it. It's throwing codes for the COP and I pulled the plugs and found a broken one. Other than this little hiccup, the car has been a dream to drive and this is the FIRST ever problem I have had on it, other than normal wear and tear.
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
