Spark Plug Question
  • Thread starter Thread starter Jarvis
  • Start date Start date Sep 1, 2013
1 of 2 Next Last
Jarvis
57
Fort Benning, GA
Sep 1, 2013
  • Sep 1, 2013
I got some plugs and wires from LMR.
Plugs: Motorcraft: SP- 406, AGSP32C
Wires: FRPP 9mm
Question what should the Gap be? I saw the table that shows gaps but these plugs weren't on there. I
don't know the timing, or how to check. Mods are in the siggy. Thanks for the help guys.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Sep 1, 2013
  • Sep 1, 2013
stock gap should be fine for you
From "The Official Ford Mustang 5.0 Technical Reference & Performance Handbook 1979-1993" Ford Racing Part No. M-1832-Z4
Page 274
"Spark Plug Applications" table
Year---------Engine--------------Motorcraft number-------Gap (inches)
1979---------5.0L (49 state)-----ASF-52------------------.050
1979---------5.0L (california)-----ASF-52-6---------------.060
1980---------4.2L (all)-----------ASF-42------------------.050
1981---------4.2L (all)-----------ASF-52------------------.050
1982---------4.2L (all)-----------ASF-52------------------.050
1982-1985---5.0L carbureted-----ASF-42------------------.044
1982-1985---5.0L CFI------------ASF-52------------------.050
1986--------5.0L H.O.------------ASF-34 or 44------------.050
1987-1993---5.0L H.O.-----------ASF-42------------------.044
1993--------5.0L GT-40 (Cobra)--AWSF-42C---------------.050
1. Factory electrode gap specifications are shown on each Mustang's VECI label that is affixed underhood. The relatively wide gaps specified created the fat, long-duration spark needed to ignite the lean mixtures prescribed for most normal operating conditions.
2. Most non-Cobra 5-liter motors typically run well with spark plugs gapped at .052 inch. For normally aspirated engines in high-performance service, a plug gap between .040-.045 inch is suggested by many tuners. Those same sources also suggest .028-.034 inch in turbocharged, supercharged, and nitrous-fed five-ohs.
Jarvis
57
Fort Benning, GA
Sep 1, 2013
  • Sep 1, 2013
So .044? They're out of the box at .51. Also seems to be running a tad rich, does that change anyything?
madspeed
Colonel Mustard
1,332
204
Sep 1, 2013
  • Sep 1, 2013
yep, .044. As far as running rich, pull your codes even if the cel is not on
Jarvis
57
Fort Benning, GA
Sep 1, 2013
  • Sep 1, 2013
I tried to pull codes, My CEL doesn't come on at all. When i start it, and when I jumped the diag connector
madspeed
Colonel Mustard
1,332
204
Sep 1, 2013
  • Sep 1, 2013
pick up the cheap equus ford code reader. it plugs directly in to your diag connector and does everything for you
http://www.amazon.com/dp/B000EW0KHW/?tag=stangnet-20
Jarvis
57
Fort Benning, GA
Sep 1, 2013
  • Sep 1, 2013
That's not a bad idea, I might pick one up at the store later.
madspeed
Colonel Mustard
1,332
204
Sep 1, 2013
  • Sep 1, 2013
have had mine for a dozen years
Jarvis
57
Fort Benning, GA
Sep 1, 2013
  • Sep 1, 2013
Nice! I've been waiting at least that long to get my Fox
stykthyn
5,232
2,652
223
gainesville
Sep 1, 2013
#10
  • Sep 1, 2013
  • #10
that reader is a god send
madspeed
Colonel Mustard
1,332
204
Sep 1, 2013
#11
  • Sep 1, 2013
  • #11
@stykthyn, how do you do initiate the koer test? I can't semyo locate my manual and haven't done that on in a long ime
stykthyn
5,232
2,652
223
gainesville
Sep 1, 2013
#12
  • Sep 1, 2013
  • #12
I plug the tester in power it up and then start the car. the manual has more details on how to extract more info such as the cylinder balance test. you have to press the gas to floor when the reader starts to flash or all testing stops and the reader cycles down.
If you try to plug in after the car is running it wont pull any codes, or at least I've never been able to.
vfast
113
Va
Sep 1, 2013
#13
  • Sep 1, 2013
  • #13
51 is ok
JD1964
there is enough sticking out to grab on to
3,605
1,611
194
Maryland
Sep 1, 2013
#14
  • Sep 1, 2013
  • #14
I just ordered one of those digital code readers from Amazon for future use.
On the question of spark plug gap, I'm running Autolite #25's. The label under the hood on my '92 says 52-56 for the gap. I set my plugs at 54.
Should I pull them back out and re-gap to 44 instead?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 1, 2013
#15
  • Sep 1, 2013
  • #15
The 54 is the recommended gap from the factory. You should be fine there but if you want tighten the gap to 44 and see if it impacts the performance. Equally important is what type plug you run.
Those heads call for a certain size and reach plugs - 14mm by 3/4". When I had E brock heads I ran the same plugs ( Autolite 3924's one step colder) gapped at 54.
http://www.framcatalog.com/Competitor.aspx?b=A&pn=AGSP32C&em=True
http://www.edelbrock.com/automotive_new/mc/cylheads/ford/sb_perf_rpm.shtml
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 4, 2013
#16
  • Sep 4, 2013
  • #16
Why blow $25 on a code reader that only works with old Ford EEC-IV systems when you can pull codes and run self-tests with a scrap piece of wire and a $0.99 12v test light? If you have a working CEL, then all it takes is the piece of wire.
Plug gap is more reliant on the ignition system and induction than the plug itself. I would use the stock gap with a stock TFI ignition and no power adders or high compression.
Jarvis
57
Fort Benning, GA
Sep 4, 2013
#17
  • Sep 4, 2013
  • #17
I dont have a CEL, i tried.
JD1964
3,605
1,611
194
Maryland
Sep 4, 2013
#18
  • Sep 4, 2013
  • #18
I have a habit of blowing $25 on all kinds of things. I see your point though. I used to get the codes from my old GM OBD1 cars with a paperclip in the diagnostic port and count the CEL flashes.
madspeed
Colonel Mustard
1,332
204
Sep 4, 2013
#19
  • Sep 4, 2013
  • #19
you can still pull the codes without a cel. Theres a how to in jrickters surging idle checklist thread. That being said, I still prefer my handy $25 reader, guess i'm getting old
65ShelbyClone
4,675
38
119
Sep 5, 2013
#20
  • Sep 5, 2013
  • #20
I know, I was making the indirect general statement that in a worst-case scenario, all you need is a $1 light and a piece of wire.
1 of 2 Next Last
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
