- Feb 3, 2004
- 128
- 0
- 0
I just replaced my plugs on my 289, yeah it is a bit of a pain to do. But I found a neat little trick that might help someone. On the #3 cylinder I think only a normal 5/8 1/2 inch drive socket would fit but the end of the plug stuck out a little. So I took a crappy 1/2 in extention and drilled a fairly large hole in the end for the plug to slip into and it worked very well! You just have to drill a big enough hole b/c the plug goes in kinda slanted. Well there ya go hope that helps!
You think that's tough, try a 67-70 big block Stang.
