Spark Plugs + 160T-Stat
1991RWHP
59
Illinois
If I'm going to go to a 160 thermostat, do i need to go hotter plugs? I know if you put boost on a car you need colder plugs, but i cant remember if Hotter plugs work better with a 160 thermostat or do i do Colder temp plugs... and why?
Also! I've got a check Engine light on my 93' Notch... How do i go about retrieving codes given its OBD1.
Thanks for everyone's help ahead of time.
Because optimum coolant temps with regard to engine wear are in the 190-210*F range, we'd assume the 160* stat is to accomodate a cooling system issue and that you will still run in the 190+ range. In any case, no need to change plugs. Operating temps and plug heat range are not related like that (you play with plugs when you have preignition or fouling, power adders, etc).
Jrichker has info on pulling codes in the Useful Tech Sticky.
Good luck.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
