spark plugs are white
dadiesel5
31
i have about 1 hour of runtime on my rebuilt engine and i checked the plugs and they are solid white, it will rub off if i rub it hard with my finger. the plugs are
ngk fr5 and i checked the gap and its 0.35. what does this mean?
this should help it's from ngk
http://www.ngksparkplugs.com/techinfo/spark_plugs/installation.asp?nav=31300&country=US#installing
3. Gapping
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
If its fuel injected, reading plugs is not an accurate way of determining whether or nor the engine is running lean unless you do a full throttle run, then immediately shut down the engine and check the plugs. EFI mustangs tend to run lean and have white plugs at idle and part throttle cruise to get the engine warm quicker, to reduce fuel usage, and for emissions. The only way to know for sure if the engine is running lean is by using a wide band O2.
A fuel pressure regulator is a band aid what wont work for long because the computer will adjust out any small changes in the fuel pressure, by adjusting the fuel injector duty cycle.
i bought the fr5's because they was reccomended in the book that was with my heads (trickflow twisted wedge) also do you think i should gap my plugs at .054 or a little smaller since my motor is built and has a little higher compression than stock. thanks for the link.
