Spark Plugs For Nitrous
Id also like to know as i've been considering spraying until i can save enough money for a supercharger. 125 shot seems kinda alot are you sure thats going to be safe? How much was the entire Nozzle kit & where did you get it from?
kirkyg
Do you have to run different plugs when using nitrous? I am about to buy a kit within a month and i didnt think anything about plugs? How come the kits doesnt tell you to buy different plugs?
Actually NX does. In their instructions they tell you to stay AWAY from platnium plugs if you have nitrous. I don't really know why you have to change to copper. Mabye the other companies don't. Good thing is the copper autolites are only a little over $1 each, nice to buy something cheap for a change.
2002BLGT said:
autolite 764s or ngk TR6s for up to 100 shot anything over that BR7EF ngks . autolite 103s might also work , always gap in the .035 range
Silverstang with your 125hp NOSzle kit don't run Autolite
764's because they are the stock heat range and you will blow up your
engine.I would seriously run some plug that is two heat ranges colder
like Autolite AR94's or NGK R5671A-9 and if you are going to run that
125hp shot I say upgrade your intank fuel pump and fuel pump that way
your engine will get the extra fuel needed to be a the safe side! A .35
gap is fine for nitrous use.I say Good Luck.
FYI the BR7EFs are 2 heat ranges colder , where do you get your info from man ???
