spark plugs
Autolight 24's. One degree colder then stock.
platinum plugs dont work that great w/ our cars. The best ones to use are the autolight or motcraft plugs. There cheap and they work the best for our motors.
I use Autolite 3924s. Autolite makes Motorcraft plugs. I used to use NGK V-power plugs, but the Autolites work the same, so why spend the money.
Platinum plugs don't suck, they just aren't as performance friendly. I use Platinums in the beater car.
Kurt
Since several people have given part numbers, I feel like I should mention something -- make sure you get the correct type of spark plug for your application. Autolite 24's and Autolite 3924's are equivalent plugs, with a different physical design -- the 24 is a beveled seat design to be used with iron heads. 3924's are a gasketed long-reach plug for use with aluminum heads. Do not use 24's with aluminum heads, you'll damage the head. And in case you were not aware, Autolite == Motorcraft. :nice:
Dave
