  • SN95 4.6L Mustang Tech
Spec clutches?
  • Thread starter Thread starter LS2 KLR
  • Start date Start date Aug 5, 2004
LS2 KLR
452
Houston, TX
Aug 5, 2004
  • Aug 5, 2004
I put a stage 2 in my car in Feb and now it is slipping. It only happens on the spray. I have heard of making a stage 2 hybrid which is suppose to be making it into a stage 3? And should I go with a Spec stage 3 or look at something different? And who has the best prices?
Mr GT 02
548
Peabody, MA
Aug 5, 2004
  • Aug 5, 2004
Get a Different Clutch...dont bother with Spec no more...SPEC sux!
KaPPaBaLL
1,326
BAYAREA
Aug 5, 2004
  • Aug 5, 2004
Spec clutches use to carry a good reputation until they wanted to cheap out on the quality of their products. Reason your clutch is slipping can also be because it wasn't installed properly. Are you getting any clutch pedal vibrations with the slipping clutch? I also highly recommend you get a steeda clutch quadrant and firewall adjuster. One more question has your friction point of your clutch move ever since you've gotten the spec clutch?
U
UNVMATT
294
COLUMBUS
Aug 5, 2004
  • Aug 5, 2004
Heck with the Spec! For a stage II equivalent get a better series Zoom or Centerforce! Or at least get a FRPP King Cobra.
Spec sucks. Nearly everyone that has installed one recently regrets it.. Less than 20K miles and its already time for a change.
LS2 KLR
452
Houston, TX
Aug 5, 2004
  • Aug 5, 2004
I need something equivalent to the stage 3. I'm just not sure who makes one. I don't notice any vibrations. Under normal circumstances it drives fine. The clutch has almost 5k miles on it and around 20+ dyno pulls. I also still have my stock flywheel Getting the steeda adjuster and quadrant is a good idea, I'll most likely do that as well.
StangLou
1,264
Holly Springs, NC
Aug 5, 2004
  • Aug 5, 2004
Specs seem to be hit or miss. I for one love mine. It bites like mad and doesnt feel like there is a chance in hell of it every slipping. Granted Im not putting out huge #'s or anything, but mine works GREAT!!!
I think the stage II is only good for up to 400-450lb/ft of torque. If your built pretty good and spraying then you very well could be over the 400 mark which could cause your slipping. Just a thought!
J
JoeySperz
305
Mountainside, NJ
Aug 5, 2004
  • Aug 5, 2004
I have the stage three. I like it. The material used in the stage 2 is significantly less durable than the stage 3. Try www.kmodifiedracing.com, they have the best pricing I have seen.
mpcv2000
2,371
Montreal , Quebec !
Aug 5, 2004
  • Aug 5, 2004
I have a SPEC II in my car for one and 1/2 year , I spray a 100 shot on Nittos and it never ever slept on me .
I don't push big numbers ( 315 RWHP & 424 Ft-Lbs torque SAE ) and my car is heavy 3747LBS so if it had to slip it should have been by now .
Maybe your clutch was not adjusted properly or something
I just replace my clutch bearing last month and I took a look at the clutch and it's perfectly good for all summer and probably the next one too..
LS2 KLR
452
Houston, TX
Aug 5, 2004
  • Aug 5, 2004
Thanks, I sent them an email.
02mingreyconv
127
Bartlett, IL
Aug 6, 2004
#10
  • Aug 6, 2004
  • #10
The torque capacity of the stage 2 SPEC is only 530 and you are pushing 550+ with the 200 shot so it is no wonder that the clutch is slipping.
I am still debating weather to get a SPEC stage 3 or the king cobra myself...
Fox In search of a Spec clutch dimension.
  • PonyGTrider
  • Jun 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2025
PonyGTrider
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
K
Procharger Stage 2 - 2013 Mustang GT Minor Hiccups
  • KHills5058
  • Oct 9, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 9, 2025
KHills5058
K
K
2013 Mustang GT Procharger Stage 2 Kit Issues
  • KHills5058
  • Oct 9, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2025
KHills5058
K
