  • SN95 4.6L Mustang Tech
specs for c/c plates?
  • Thread starter Thread starter mijo_latino
  • Start date Start date Apr 7, 2005
M
mijo_latino
179
Canton, Michigan
Apr 7, 2005
  • Apr 7, 2005
What are the right specs to align the front end? Are there differences or should i just try to get it close as possible to factory spec?
I'm putting on UPR c/c plates in the morning, after, the tech thats going to align the car wants to know the #'s. I thought it was odd, but i don't know if there is "better then factory" specs out there or i should just tell him get it close enough to factory.
Thanks in advance.
M
mijo_latino
179
Canton, Michigan
Apr 8, 2005
  • Apr 8, 2005
ok, i searched myself and found the specs on good ol' Corral forums.
they are:
1-1.25 neg camber
5-6 deg positive caster
1/16 total toe-in
but, now i have a c/c plate install question. The instructions say remove the dust cover if im using the factory struts. I'm not, so i just leave them on right? I guess i'll work on the other side to see is anyone posts....
M
mijo_latino
179
Canton, Michigan
Apr 8, 2005
  • Apr 8, 2005
to remove or not to remove?
sadness...
after searching and thinkin, I guess i've figured it all out:
UPR states that you need to remove the dust cover if factory struts will be used.
My tokico struts are like replacements, so I should consider them "factory like"
issues with how the dust cover gets in the way of adjusting makes me think i should take the dust cover off(the top of the dust boot fits into the large strut hole making adjustment restricted)
No dust cover = issues with the struts later...
Simple install other then trying to figure out all this mess. Should of went with mm plates, read their instructions and are much more straight foward
Alginment coming as soon as i decide.
anyone?
H
HMSPORT
Banned
Mar 30, 2005
60
  • Apr 8, 2005
Put as much caster in as you can(4-4.5 degrees pos.). It helps with straight line tracking and gives better steering feedback/input. total toe do as stated by mijo_latino. As for camber, you need to decide how you are going to drive /where the car. If you do allot of highway/straight driving, I would'nt go with more than 1. neg. During (at speed) cornering, the added positive caster will give the outside tire more neg. camber allowing for a larger "footprint" of the tire. Most people don't know that when you change one spec (toe,caster,camber) it changes the total alignment.
mransr
1,188
36
98
Riverside, SoCal
Apr 8, 2005
  • Apr 8, 2005
you might try cutting that rubber stuff off the top of the dust boot with a hacksaw...
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 8:51 AM
Rdub6
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Thursday at 10:40 AM
AeroCoupe
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
