  • SN95 4.6L Mustang Tech
Speed Cal Problem
  • Thread starter Thread starter spdracer
  • Start date Start date Jan 28, 2007
spdracer
  • Jan 28, 2007
i have a 97 gt with 4.10's and i just installed my DM speedcal, my problem is that when braking the car has stalled on me 4 times in the past few hours after install, as well the speedo will not work until i get to 60km/h and then the needle shoots up to it, and starts to read accuratly... any suggestions on what the problem may be>> thanks guys
droid#83853
carfax for friendship
Dec 30, 2006
28
Beating my car to death with a tire iron
Jan 28, 2007
  • Jan 28, 2007
Check your wire connections. For a 1997 why did you waste your money on a Speed Cal? All you need is the little nylon gear that pops into the trans. If your connections are okay, check all the little switches to make sure they are set right. If they are, then you need a new Speed Cal. They are junk. I went through four of those before I demanded a refund. Two of them did the same thing yours is doing. I nver got the Speed Cal to work right. I bought a tuner instead to change my ratio.
Just get the speedo gear. They come in different teeth sizes. Like 16,17,18,etc. I am not 100% sure what size you need for 4.10's, Look on eBay. http://cgi.ebay.com/ebaymotors/83-98-Mustang-23-tooth-3-73-4-10-Speedo-Gear-T5-T45_W0QQitemZ260079592183QQihZ016QQcategoryZ33731QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
spdracer
  • Jan 28, 2007
i have a speedo gear but i heard any gear over 3.73''s they dont have a specific speedo gear for them so i never botherd installing it.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
D
95 cobra (stock) Fuel pump or Distributor?
  • drop5ohhh
  • Jul 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 1, 2025
gkomo
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
