speed density guys help
  • Thread starter Thread starter rickd93_lx
  • Start date Start date Feb 21, 2007
rickd93_lx
162
  • Feb 21, 2007
quick question if a map sensor is bad willl the car still run when the sensor is disconected, simmilar to a mass air? if it shuts the car off is it good? in theory ant way. thanks in advance
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 21, 2007
  • Feb 21, 2007
I ran a map car with the vacuum line disconnected to it so that it wasn't getting the reading it needed and it still ran. Not well but it still ran. Usally when they are going or gone you start using tons of fuel becaus the computer goes into limp mode.
F
facemelter71
60
cincy
Feb 21, 2007
  • Feb 21, 2007
My 86 had a kinked vac line to the map sensor and the car ran real fat and when i stepped on the air pedal it would fall flat on its face then pick up.Replaced line with new and wow what a diff.I actually have a tester here at home with me,if you want you can send it to me and ill check it for ya.
HISSIN50
34
129
Feb 21, 2007
  • Feb 21, 2007
The guys have you covered - it will default on the real rich side and can stink pretty decent.
Good luck.
rickd93_lx
162
  • Feb 22, 2007
thanks guys, that answred my question, the car has a major smell of gas waste it big time, im going to grt a new one tommarow see what happens. thanks again
V
v8only
2,378
22
49
Feb 22, 2007
  • Feb 22, 2007
i'd check your vacuum pressure first
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
