speed density question
  • Thread starter Thread starter gt40_2003wes
  • Start date Start date Oct 17, 2005
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 17, 2005
  • Oct 17, 2005
if i get a cam and it aint a sppeed density cam will my car have problems running?
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Oct 17, 2005
  • Oct 17, 2005
shouldnt. But it all depends on the cam.
gt40_2003wes
Aug 14, 2005
461
ky
Oct 17, 2005
  • Oct 17, 2005
i was thinking bout the e303 will it have probs with this cam?
RsStanG1987
569
9
79
Dupont PA
Oct 17, 2005
  • Oct 17, 2005
You may have to adjust the Idle. Your car is mass air right?
gt40_2003wes
Aug 14, 2005
461
ky
Oct 17, 2005
  • Oct 17, 2005
no speed density
E
emagdnim
391
15
28
Oct 17, 2005
  • Oct 17, 2005
the e303 will give you problems , go with a comp cams or crowler with a 114 lsa and your good to go. The e303 isnt that good of a cam theres much better out there that work with SD. Even the comp cams XE270HR works good with SD. Im running the nx264 and it runs great.
D
Daggar
3,902
  • Oct 17, 2005
E cams do not run particularly well with SD without a custom tune. It's getting harder and harder to find places that are able to burn a chip for SD computers. The hardware is still out there... it's the software for Ford SD EECs that's difficult to find.
gt40_2003wes
Aug 14, 2005
461
ky
Oct 17, 2005
  • Oct 17, 2005
ok are there anything else that will cause my car to have fits besides the cam?
E
emagdnim
391
15
28
Oct 17, 2005
  • Oct 17, 2005
Any injectors larger then 24 will give you problems , You will also need a afpr .
gt40_2003wes
Aug 14, 2005
461
ky
Oct 17, 2005
#10
  • Oct 17, 2005
  • #10
yea i was plannin on orderin a fuel pressure regulator when i order a cam.will the trick flow stage one work good with my sd?
E
emagdnim
391
15
28
Oct 17, 2005
#11
  • Oct 17, 2005
  • #11
Can you paste the specs of it?
gt40_2003wes
Aug 14, 2005
461
ky
Oct 17, 2005
#12
  • Oct 17, 2005
  • #12
not sure on the specs but ill try to find em shouldnt be to hard.
87gtconv
ragtopman
2,595
Southern Calif
Oct 18, 2005
#13
  • Oct 18, 2005
  • #13
I am planning on leaving my cam and heads alone and just going with 1.7 Cobra RR, new valve springs, a Cobra intake with a 65mm TB and leaving the injectors at 19 lbs. Any thoughts?? Yes, I am still SD.
P
POWER302
427
IL
Oct 18, 2005
#14
  • Oct 18, 2005
  • #14
Did you even read the topic before you clicked on this thread?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 18, 2005
#15
  • Oct 18, 2005
  • #15
trickflow stage one wont work well
87'GTstang
1,025
#16
  • Oct 18, 2005
  • #16
Keep the LSA around 114* (stock cam is 115* btw) and the keep the duration smallish (something around 260* advertised or so) and it will be a hit or miss with the valve lift selection. Seriously, just do what thousands of other 87' and 88' stang owners have done and convert to mass air - it opens a whole new door in the light of "what do I want to do next?" instead of "what can I do?".
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
