speed density/supercharger ??s
slushbox_drop
I tried to search this topic before posting, but I couldn't find the information I was needing. So....
I know its possible, but what all is required for a s/c on a speed density motor? What is the best fuel pump/injector size? What is the best way to tune it? Any input would be appreciated. Thanks!!
Best injector size would be a set of 19s with an FMU. You'll also require a one way check valve to bleed off boost pressure prior to it getting to the MAP sensor. Tuning is just as important as with MAF and will need to be accomplished mechanically unless you're able to find somone with the hardware/software capable of burning you a chip for the older SD computers.
Another route less travelled would be something like the Accell ECU. Very expensive... at that point you have to weigh whether or not you'd be better off just converting to mass air.
