  • SN95 4.6L Mustang Tech
Speed limiter on '04 2v?
  • Thread starter Thread starter 40th GT
  • Start date Start date Oct 11, 2005
1 of 2 Next Last
40th GT
916
Lawrenceville, GA
Oct 11, 2005
  • Oct 11, 2005
Just wondering if 99-04 GTs came with a speed limiter? I couldn't make it past 138, and I know some guys on here did 145-150 in theirs.
Also, what gear should I be in? My car was screaming at 6k in 4th gear and I was at 133-135, so I had to slide into 5th.
Oh yeah, this test was done on a dead road, where no one else can get hurt besides me.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Oct 11, 2005
  • Oct 11, 2005
Most ive ever done in my GT was 100, the 2000 GT I had up to 135-145 and it felt like it wanted to take off, damn 4x4 . But to answer your question, id say 140-145 is about it for a bone stock 5-speed GT.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Oct 11, 2005
  • Oct 11, 2005
i ve hit 145 in my GT when it was bone stock then let off but it was a one time thing just to get it out of my system
ponysarepretty
578
  • Oct 11, 2005
The speedos aren't calibrated for more than 100 mph.
D
Dragstr05
643
Stafford VA
Oct 11, 2005
  • Oct 11, 2005
I would see how high I can take my 00' GT, but I really dont want a ticket. Actually, that fast I think its straight to jail.
F
Fubar02GT
73
Bradford
Oct 11, 2005
  • Oct 11, 2005
my 02 GT is only good till 138 as well, and i don't have tuner yet..we'll see afetr that
BlueThunder02
  • Oct 11, 2005
i had the 03 gt up to 137 and it still had plenty left in it, problem was, there wasnt plenty of road left.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 11, 2005
  • Oct 11, 2005
Have you done a gear swap to the rear by chance? With 3.27's, a '99-'04 Mustang will top out in 4th gear, but not in 5th. But....if you swap out to a set of shorter gears like 3.73 and higher (numerically) you'll run out of gear in 4th, but will still lack the power to pull it in 5th.
My old 5.0L was faster in 4th gear with the stock 2.73's in it than it was with the 3.55's. It would burry 1:1 4th gear ratio pretty easily, but still not make enough power to pull the .68:1 5th gear all the way out to redline.
billfisher
1,296
huntsville, AL
Oct 11, 2005
  • Oct 11, 2005
138 is fast enough isn't it?(i coast at 135)
hotmustang331
2,967
Bastrop,TX
Oct 11, 2005
#10
  • Oct 11, 2005
  • #10
Um I have 3.73s and when i was making 248RWHP (about 20 more than stock) I had mine all the way to 148MPH in 5th gear (3.73s). If I had the stock size tires it would have read a good 150. Stock woulnt have any problem carrying over 5th with 3.73s for a good ways. When I had an O/R X and E waterpump and stock gears, the car would pull in 5th...but just BARELY.
And to the original poster...YOU CARRIED IT OUT TO 6K! In freggin 4th? Im sure it took forever just setting at 5800-6K for a long time....well I guess you know your engine is sound now lol. But hey, iv been to 6300-6400 in 4th with my gears and cams (127ish)...but it doesnt hang around if you know what I mean. SO im guilty too.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 11, 2005
#11
  • Oct 11, 2005
  • #11
I've done about 150 in 5th gear at about 4250 rpm.. still had some pull to it making it go.. had to let off due to the fact i had to exit the interstate soon
I would like to get something that could tell me my exact speed and top it all the way out.. just for ****s and giggles
sgarlic
3,085
Oct 12, 2005
#12
  • Oct 12, 2005
  • #12
Damn.. you guys really go that fast? I've never been past 100 in the '04.. the '88 on the other hand..... woo-wee.
ocbaud
239
Midwest City, Oklahoma
Oct 12, 2005
#13
  • Oct 12, 2005
  • #13
here's my speeds:
'01 stang gt : 130mph(so far)
'02 stang v6 : 118mph(limiter)
'86 chevy c10 : 134mph(no more gearing)
J
jmajorboner
64
#14
  • Oct 12, 2005
  • #14
I read somewhere that the computer shuts off gas at 149mph
baken78
Tha colddddd
Oct 12, 2005
#15
  • Oct 12, 2005
  • #15
Had mine up to 150 after disconnecting the exhaust from the cat back. Seems these engines like less backpressure. I reconnected my exhaust with the aftermarket mufflers and I could only run up to about 136... No clue why.
By the way I'm new here so HI everyone!
goshia
252
Mead, Colorado
Oct 12, 2005
#16
  • Oct 12, 2005
  • #16
Yes the Speedo is limited. Use a diablo sports predator and you can remove the limiter.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 12, 2005
#17
  • Oct 12, 2005
  • #17
Welcome to the board baken
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 12, 2005
#18
  • Oct 12, 2005
  • #18
Whats the point of having the limiter removed?? If we had a autobahn then yeah but I would not want to get stopped by the Po Po for going 100+mph, just my .02.
StalkerStangGT
24
Hurricane, WV
Oct 12, 2005
#19
  • Oct 12, 2005
  • #19
With ur stock 3.27's my 04 GT bounced off the revlimiter at 140 mph and fell on its face when u shifted to 5th
with my 3.73's i bounce revlimiter in 4th at 120....then when i shift to 5th it falls on face but it still pulls a lil.....i've had my car to 150 then i let off.....i have a predator but i havent adjusted the speed limiter.....if felt smooth to me.....didnt seem i was going that fast
40th GT
916
Lawrenceville, GA
Oct 13, 2005
#20
  • Oct 13, 2005
  • #20
Yeah, once you get caught for going 100+, you're off to jail.
I think I'll bypass the speed limiter and take her to the salt flats or something. I wanna see what it can do with a stock body/engine.
1 of 2 Next Last
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
Bogging @ High Rpm
  • RainbowThunder
  • Dec 11, 2014
10K
SN95 4.6L Mustang Tech Dec 21, 2014
RainbowThunder
R
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
Found the limit on a stock teksid 2v
  • Mr. Rustypwnz
  • Nov 16, 2011
5K
1996 - 2004 SN95 Mustang -General/Talk- Nov 16, 2011
Mr. Rustypwnz
  • Locked
Kenne Bell Supercharger 99-04 Mustang GT
  • Rick10
  • Apr 11, 2011
  • Engine and Power Adder Parts
12K
Engine and Power Adder Parts Nov 28, 2011
