  • SVT Tech Forum
speed vs rpm
  • Thread starter Thread starter curt93t/t
  • Start date Start date Jun 20, 2004
C
curt93t/t
  • Jun 20, 2004
Question, I don't have a stang so I need your advice. I have a guy showing a pic of him doing 138mph with an RPM reading of about 4,300. Do these numbers seem to jive? The reason why I am raising an eyebrow is because he claims to have taken this pic himself and it is CRYSTAL clear and only of the gauge cluster. I know that there is a self test on the stang in which the needles move. What do you think?
9COBRA7
116
Just outside Detroit MI
Jun 20, 2004
  • Jun 20, 2004
thats somewhats of the range it should be in depending on the gear he has set up in the rearend.
missouri_guy197
1,441
St. Louis, MO
Jun 20, 2004
  • Jun 20, 2004
138mph at 4300rpms in 5th gear with a T45 would have him having 3.55 gears in the back...
85GTlover
704
  • Jun 20, 2004
Those numbers seem to be logical and the above post ,if correct......likely, makes sense to me. I take it you think the rpm's should be higher at those speeds?
C
curt93t/t
  • Jun 20, 2004
I was thinking that the RPM's would be higher if he was running stock gears. I'm not saying that they don't jive, just I don't believe he was able to take that perfect of a pic at that speed. There is absolutely no light in the background.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • AeroCoupe
  • Aug 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 14, 2026
AeroCoupe
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • SVT Tech Forum
