Speed vs RPM
  • Thread starter Thread starter Rockin302
  • Start date Start date Oct 31, 2004
1 of 2 Next Last
Rockin302
236
California
Oct 31, 2004
  • Oct 31, 2004
Just curious, I have a pretty much stock 90 lx 5.0 coupe with a stock 5 speed transmission. When I'm cruising at 60 mph what should the rpm's be reading??
Feels like the previous owner slapped a set of gears in the car. I'm at around 1800-2000 rpm when going 60 in 5th gear. Is this normal??
PhLoBuS
473
Beverly, MA
Oct 31, 2004
  • Oct 31, 2004
3.73's maybe, on my AOD it is around 2krpm when cruising around 60 and I have 4.10s.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 31, 2004
  • Oct 31, 2004
Yeah he has put some gears in or your tachometer is off...
I'm at 2050rpm at 60mph with 373's...
You may have 355's?
I know in my 2000 Gt that I had 327's (stock) and was at 2krpm at 70mph...a nice interstate gear
With my 373's I believe there closer to 2400rpm at 70mph...so I avoid the interstate usually...I hate the constant "high rev" on the engine...its like driving around in 1st gear at those rpms (though it sounds good)...just doesn't appeal to the longevity side of me
Rockin302
236
California
Nov 1, 2004
  • Nov 1, 2004
Hmmm, maybe those gears are a cause of my problems with the driveline. If the gears weren't installed properly(backlash, etc...) then it's probably the cuase of all my symptoms!!!
HISSIN50
34
129
Nov 1, 2004
  • Nov 1, 2004
Rick, that does sound high (higher than stock). i would jack the rear and count the ratio of wheel rotation to DS rotations. this is your gear ratio.
im turning ~1500 rpm at 60 mph (i dont drive at 60 - dont even shift into 5th till 65, so this is a close guestimate).
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Nov 1, 2004
  • Nov 1, 2004
What problems?
HISSIN50
34
129
Nov 1, 2004
  • Nov 1, 2004
4dStang said:
What problems?
here:
http://forums.stangnet.com/showthread.php?t=513271
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 1, 2004
  • Nov 1, 2004
I would say that sounds about right. I dont think that i have gears in mine and at 2000rmp i am doing 70. Isnt there some kinda calc. thing around here that tells you?
Funanin
356
Horsham, Pennsylvania
Nov 1, 2004
  • Nov 1, 2004
sounds like 3:73's to me. anywhere from like 1950-2050 rpms is 3:73's in 5th
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 1, 2004
#10
  • Nov 1, 2004
  • #10
Here, i still think 3.08's. See for yourself.
http://www.corral.net/tech/gearcalc.html
Rockin302
236
California
Nov 1, 2004
#11
  • Nov 1, 2004
  • #11
Thanks for the links!! So it looks like I have 3:55's in mine.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 1, 2004
#12
  • Nov 1, 2004
  • #12
That is what I thought...based on the rpms you gave at the mph given...
Do what hissin said and count the number of tire/driveshaft spins you get to get an pretty accurate teller...unless you already have...
T
tHeOnEGT
175
new jersey
Nov 11, 2004
#13
  • Nov 11, 2004
  • #13
townthug,
thanks for that link, i was looking for somethig like that since i brought my car to the track. Since i bought the car my rpm would be 6000 and doing only 100 mph in 4th. The previous owner said it had 4.10's so i figured the speedo or mph was off. Finally took it to the track and was crossin the traps at 103 mph at 6200 rpm. I checked at the gear calculator and low and behold i really have 456 gears. Just like to say thanks. What you guys think 3.73 or 4.10's. Im leaning toward the 373's???????
HISSIN50
34
129
Nov 11, 2004
#14
  • Nov 11, 2004
  • #14
tHeOnEGT said:
townthug,
was this from your stock tach or aftermarket? i might look for error in that area. also, one can jack the rear end and note DS to wheel rotation to figure the ratio.
good luck.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 11, 2004
#15
  • Nov 11, 2004
  • #15
tHeOnEGT said:
townthug,
Yeah go with the 373's...you will lose SOTP feel but the driveablity/mileage/less wear on engine will increase...
Despite popular belief...it is okay to fear the gear...especially if it is daily driven car...
HISSIN50
34
129
Nov 12, 2004
#16
  • Nov 12, 2004
  • #16
The One, not to beat a dead horse, but i would be sure of what you have before you decide - the relative difference will matter. as i recall, i think one can get 3.90:1 gears too, no? might be a compromise bwtween the 3.73's and 4.10's.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 12, 2004
#17
  • Nov 12, 2004
  • #17
Yep 390 gears are an option...but FRPP doesn't make them so there usually not as popular...I'm happy with my 373's...I wouldn't go up or down on them since I drive it everyday and it provides a good kick...and liveable highway rpms though I try to avoid the interstate if it is for a long distance...
HISSIN50
34
129
Nov 12, 2004
#18
  • Nov 12, 2004
  • #18
thanks for the info and clarification.
Rockin302
236
California
Nov 12, 2004
#19
  • Nov 12, 2004
  • #19
Even with my stock gears (double checked, I have 3:27's) there's a drone at highway speeds, approximately 65 mph. Maybe I should switch out to the 3 chamber delta flows.
HISSIN50
34
129
Nov 12, 2004
#20
  • Nov 12, 2004
  • #20
Rockin, what RPM do you see for that drone? RPM and not speed (as you know) is what determines drone.
you must not have stock mufflers then, right?
1 of 2 Next Last
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
