Speedo Bouncing
  • Thread starter Thread starter beatergt
  • Start date Start date Aug 28, 2011
beatergt
11
  • Aug 28, 2011
.....My speedometer is really active, when I pull away the speedo bounces from 0 to 140, after about 40mph the speedo is now resting @ 130mph, when I slow bouncing again. It appears thae the mileage & trip set are working right.......could this be the speedo cable?............
BlackGT89
774
Huntsville, AL
Aug 28, 2011
  • Aug 28, 2011
Sounds like you might have more than one issue. The bouncing could be caused by the speedometer gear at the transmission missing a few teeth. That would explain the grab / space / grab / space bouncing at slow speeds. The sticking could be the needle binding in some way. Do you have aftermarket white face gauge inserts ? If so, maybe they have raised up causing the needle to stick or bind ? Or course if the cable has frayed that could be causing problems as well. Usually that will bind and then unravel like a spring causing the needle so speed up and slow down. Just a few thoughts.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 29, 2011
  • Aug 29, 2011
Speedometer cable replacement for 87-93 Mustangs
Revised 6-Jan-2011 to add cleaning recommendations for lubricant saturated disk & magnet assembly..
How the speedometer works:
The indicator pointer has no direct connection to the speedo cable. It uses a drum with magnets on it to couple to the pointer. The drum turns and tries to twist the circular steel disk that is mounted on the pointer spindle. The magnetic force is all that connects the drum to the circular disk. There is very little clearance between the disk and drum, only a few thousands of an inch.
Lubrication warning
Use a graphite based lubricant for the speedo cable. It is available at most auto parts stores in a very small tube. Lubricate only the lower half of the cable. The reason for this is that if you use too much lubricant, it works its way up into the speedo head and gets between the rotating magnet and the disk. This causes the speedo to seize up and wring the indicator needle off the indicator spindle. You may be able to fix things up with non-flammable brake parts cleaner to clean the disk and magnet assembly. Plan on replacing the current cable and housing with a new cable and housing to prevent the excess lubricant from doing it all over again.
Speedometer cable replacement.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
Preparation: if you are only going to replace the inner part of the speedo cable, get lots of newspaper or a painter’s drop cloth to cover the inside front of the car. About the time you have the dirty, oily speedo cable core all over your lap and the inside of the car, you will thank me for this suggestion.
Replacing only the inner cable: see steps 1- 6, 12, 13, 17-21
Replacing the housing and inner cable as an assembly: see steps 1-11, 13-21
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Speedo head cable clip
Photo courtesy of Almost Stock
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly.
The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip. Connect VSS wiring connector back to VSS sensor.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
5LiterWes
176
15
Milwaukee
Aug 29, 2011
  • Aug 29, 2011
I had this issue, did the new cable and tranny gear thing. No help what so ever. Turned out the cluster was bad. New cluster and the speedo works great now. Tach on the new cluster is a bit bouncy though. Got one for 50 bucks of CL with 99K miles on it.
beatergt
11
  • Aug 29, 2011
, thanks for the info, however I got another OEM speedo cable coming with the tranny gear, figured I would give this a shot first, in hopes that the speedo cluster is ok........I'll let you know after I install it.........RIGHT ON
FoMoCo17
188
Aug 29, 2011
  • Aug 29, 2011
I tried a new cluster, speed solenoid, transmission gear and new speedometer cable. Ultimately, it turned out to be the cable was not lubricated enough since it makes a tight bend before it goes into the side of the transmission on AOD cars (not sure about manuals) ... Anyway, I pulled out the new cable and greased the inner cable quite liberally and that solved the problem for about 5 years. Must do it again soon since it is going from 0 to 20 again ... nothing too erratic though. I believe its the tight U bend before entering the transmission which is causing this on the Fox bodies ... seems like the cable could have been routed better and made shorter or much longer to alleviate this particular problem.
beatergt
11
  • Sep 4, 2011
still bouncing...used two good speedo cables & gears...now the final diag....rebuild speedo head....nothing else it could be now.....right?
5LiterWes
176
15
Milwaukee
Sep 6, 2011
  • Sep 6, 2011
If I ever do it again I'm trying spare cluster first. Those cables and gears are kind of a bitch. Ended up replacing mine for nothing.
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Tachometer not working…
  • BillyMoore
  • Dec 28, 2022
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2023
BillyMoore
