Speedo Cable fix
  • Thread starter Thread starter shlby123
  • Start date Start date Jun 23, 2006
shlby123
579
Dallas
Jun 23, 2006
  • Jun 23, 2006
Well while i got my dash and everything unbolted from the car. I was starting to think about my speedo not having worked in the last few weeks...I was just wondering if there is a walkthrough or step-by-step guide on how to check my speedo cable and if its torn or unhooked? Keep in mind I am a beginner but I just wanted to check on here first before I go rooting around behind the dash (if even necessary)!!
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 23, 2006
  • Jun 23, 2006
Check at the driver side of the transmission first and see if it came loose
check the speedo gear it hooks to as well
shlby123
579
Dallas
Jun 23, 2006
  • Jun 23, 2006
sorry, i dont understand.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2006
  • Jun 23, 2006
This may help some...
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
Speedo cable housing assembly with cruse control
1. Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may eiter be broken or you have damge at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jun 23, 2006
  • Jun 23, 2006
Great writup as usual.. One thing I wanted to add. When I pulled the old one loose from the transmission, the casing pulled away from the metal tip. When this happened, it didn't feel too good when my hand hit the crossmember. So, might not be a bad idea to plan a little cushio or use pliers on connector when pulling it instead of pulling casing.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2006
  • Jun 23, 2006
I have had the metal end housing separate from the cable and do the same thing - Ouch!. The speedo cable on my car is currently held together with a piece of plastic tubing and a couple of small hose clamps..
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jun 23, 2006
  • Jun 23, 2006
There was one other thing I did too. I was afraid that the cable casing might rub against the bottom of the crossmember, so I split some hose and put it around the casing so that it would rub it, not the cable's casing. May not have been needed, but thought it was cheap insurance.
shlby123
579
Dallas
Jun 24, 2006
  • Jun 24, 2006
Thanks everybody Im gonna go through the motions today and see if i can get it fixed just as soon as I finish up on the heater core. keep ya posted!
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
