speedo cable length
  • Thread starter Thread starter DJFox
  • Start date Start date Aug 6, 2005
D
DJFox
36
  • Aug 6, 2005
help -speedo cable issues
I am installing a new speedo cable and i am running into a problem. The metal piece that extends out of the cable that goes through the speedo senser is not long enough to go into the speedo gear itself. It is about an inch away from being long enough. my car is a 90 gt, is there anyway i could of gotten the wrong size cable? Thanks in advance for your reply - Jim
93GreenLX
776
Southern Maryland
Aug 6, 2005
  • Aug 6, 2005
make sure it is not a 2.3 cable
D
DJFox
36
  • Aug 6, 2005
how do i do check it out and make sure? at the dealership i told them 90 gt 5.0L
93GreenLX
776
Southern Maryland
Aug 6, 2005
  • Aug 6, 2005
i can't find any hard inf osaying one way or another that the cables are the same or different on the 5.0 2.3 AOD T-5, anything...I'll keep looking
93GreenLX
776
Southern Maryland
Aug 6, 2005
  • Aug 6, 2005
same part number...hmmmmm
J
jerryD
1,061
Gladstone, MO
Aug 6, 2005
  • Aug 6, 2005
you didn't happen to check the length with the old cable did you? can you reroute it any? is the VSS on there as well?
D
DJFox
36
  • Aug 7, 2005
its not that the cable is too short, its that the metal piece that extends out of the cable and goes through the vss and into the speedo gear is too short. the metal piece is going through the vss but is an inch short of going in to the speedo gear itself
D
DJFox
36
  • Aug 7, 2005
has anyone changed their speedo cable and know what i mean about the end with the metal piece sticking out. mine is not lonf enough to go in to the speedo gear on the end of the speedo sensor
NoSloCoupes
"I would do anything for a FREE muffler"
2,705
Clinton,IL
Aug 7, 2005
  • Aug 7, 2005
Try pulling on that piece to get some slack...it will move a little. Have you tried just plugging it in and seeing if it works?
D
DJFox
36
#10
  • Aug 7, 2005
  • #10
i tried to pull it out. is there maybe a piece that the speedo cable goes in the vss that turns the speedo gear. Maybe I am missing that ?
D
DJFox
36
#11
  • Aug 7, 2005
  • #11
bump
D
DJFox
36
#12
  • Aug 8, 2005
  • #12
stilll trying to figure this out
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2005
#13
  • Aug 8, 2005
  • #13
If I remember correctly, there is about 3/4"-1" of cable that sticks out beyond the housing. There is nothing to keep it from sliding back into the housing if the speedo head unit is not connected to the cable. The cable on the head unit end has a washer or stop made onto it to keep the cable from sliding up and out of the VSS sensor .
D
DJFox
36
#14
  • Aug 8, 2005
  • #14
the cable is already connected to the inst. cluster
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2005
#15
  • Aug 8, 2005
  • #15
In that case, I have no ideas that will help.
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
