Speedo Concerns
Purdytang9
Active User
Apr 12, 2017
54
I have a 88 lx...and as far as I can tell the gauges are original..but in 88 I thought they used the "85"mph guages...mine has the 140 And it calibrated right...and I have a working check engine light...i do know they didn't have the light in 88 But did they have the 140 speedo?...can someone straighten this puzzle out for me?
1988 Cali cars with mass air did have a check engine light. However, if you stick a bulb in the socket in an 87-88 car, the light will come on when you start the engine, but it's not connected to the self test input to display the light.
If you wish to test this, unplug your EGR. Light should come on.
No 140mph speedo in 1988, I'm guessing someone swapped in an 1989 cluster which had the check engine bulb installed. It should display upon startup. You need to run a wire to make it functional.
