Speedo correction...help
  • Thread starter Thread starter TenorPlayinGuy
  • Start date Start date Feb 24, 2004
TenorPlayinGuy
1,208
Canyon Country, Ca
Feb 24, 2004
  • Feb 24, 2004
I have an 87 mustang with 2:73 rear gears and the speedo reads about 15mph off... the reason being becaus ei have a 4cyl tranny from an 86 turbo coupe... so wha ti need to know is what speedo gear should i be using? to counter the t-birds 6tooth to the 7tooth used by v8 trannies... i cant remember what i put in there... but i have numerous spares including a 20, 21, and 23 tooth gear. so which would give me the closest fix (for the time bieng of coarse)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 24, 2004
  • Feb 24, 2004
See http://www.hanlonmotorsports.com/t5speedo.asp for help
TenorPlayinGuy
1,208
Canyon Country, Ca
Feb 24, 2004
  • Feb 24, 2004
so i would have to change the drive gear it self... doh well... guess i could live with this for the time bieng
Asha'man
1,909
Denver
Feb 25, 2004
  • Feb 25, 2004
No, just change the driven gear. You should need an 18 tooth, it's what I'm running. My tranny is from an '87 TC and I have stock 3.73's. $7 at the Ford dealer.
Ash
87gtconv
ragtopman
2,595
Southern Calif
Feb 25, 2004
  • Feb 25, 2004
Asha'man said:
No, just change the driven gear. You should need an 18 tooth, it's what I'm running. My tranny is from an '87 TC and I have stock 3.73's. $7 at the Ford dealer.Ash
but he says he only has 2.73 not 3.73 rear gears so he cant use the 18 tooth gear. He needs like a 13 and they dont make that. So he needs to either change rear gears or needs change speedo drive gear to a 7 tooth one!
84blkstang
544
Springfield MO
Feb 25, 2004
  • Feb 25, 2004
so how far off would this make the speedo?
Asha'man
1,909
Denver
Feb 25, 2004
  • Feb 25, 2004
Whoops, I guess I saw 3.73 instead of 2.73 in the original post. Pay no mind, citizens.
Ash
TenorPlayinGuy
1,208
Canyon Country, Ca
Mar 4, 2004
  • Mar 4, 2004
my speedo when running along side someone on the freeway is about 15-20 mph off...
TenorPlayinGuy
1,208
Canyon Country, Ca
Mar 4, 2004
  • Mar 4, 2004
im at 57 when they are at 75
or something like that
TenorPlayinGuy
1,208
Canyon Country, Ca
Mar 4, 2004
#10
  • Mar 4, 2004
  • #10
my speedo to be correct... or more correct for anymatter... is to change the tranny gear to an 8tooth... and the drive gear to a 17tooth... now all i have to do is drop the tranny and pull off the tail housing... oh what fun...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 4, 2004
#11
  • Mar 4, 2004
  • #11
Well, the other approach would be to pull the 2.73's our and put 3.73's in -- that'd make the speedo much closer, and the car would be much more fun to drive. 'Course, it's gonna cost a bit more....
The drive gear swap isn't complex, just takes time. You'll need the correct size drift to punch out the pin that holds the shifter rod onto the shifter shaft. And once that comes apart, be sure to catch the spring/ball assembly that's underneath it. Suggestion - there's a spring clip that holds the gear on the shaft - do not re-use it. Replace it with a new one. The one time I re-used, it came off allowing 1) the drive gear to slide on the shaft, 2) chewed up my driven gear, 3) made me go fishing around inside the case with a magnet (through the fluid drain hole) to find the retaining clip that had gone floating around inside the tranny. Just lucky it didn't get itself wedged someplace where it could do more damage.
Drivetrain At my Witts end Speedo gear ‘NEVER MIND’
  • Aoneill5.0
  • Dec 17, 2022
Fox 5.0 Mustang Tech Dec 18, 2022
Aoneill5.0
Drivetrain Speedo gear correction???
  • AbhorrentSpecies
  • Jul 29, 2021
Fox 5.0 Mustang Tech Jul 30, 2021
JD1964
C
Which speedo gears to put after a 3.73 gears on a 98 GT?
  • Chiper91
  • Jan 21, 2020
  • SN95 4.6L Mustang Tech
7K
SN95 4.6L Mustang Tech Jan 21, 2020
kiddiccarus
2013 GT speedo will not calibrate with custom tune- help!!!!
  • WIKDPNY
  • Apr 18, 2019
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 18, 2019
WIKDPNY
K
Speedo Gear ?
  • kendawg73
  • Nov 30, 2017
Fox 5.0 Mustang Tech Dec 4, 2017
kendawg73
K
