Speedo doesn't work
  • Thread starter Thread starter Jwint86062
  • Start date Start date May 5, 2010
J
Jwint86062
27
29 Palms, CA
May 5, 2010
  • May 5, 2010
When I got my 91 it came with 4:10's from the previous owner. He never changed the gear in the tranny at the end of the cable. So the speedo read higher than it should. I bought the gear and put it in. It worked for a lil while and then started going crazy again. Checked out the gear and it was shreded. I got pissed and hit my dash. now it dosent work at all. Anybody have any solutions?
H
Haus
408
  • May 5, 2010
by crazy do you mean bouncing around??
just curious. i have that problem where it bounces around
L
Lawbreaker5.0
543
Texas
May 5, 2010
  • May 5, 2010
Don't feel too bad my does the same thing and I replaced the gear mutiple times. You should pull the speedo gear back out and check it again. Mine broke the speedo gear twice so I changed out the drive gear inside. It hasn't broke the speedo gear yet but the damn thing bounces up until 40 mph and is off when I'm on the hwy.
As for it not working at all now, you prob broke something behind the dash where the cable connects.
J
Jwint86062
27
29 Palms, CA
May 5, 2010
  • May 5, 2010
Yeah , it was bouncing around. How hard is it to change the other gear? i was about to get a new cable and gear.
L
Lawbreaker5.0
543
Texas
May 5, 2010
  • May 5, 2010
you have to pull the trans, and then pull the tailshaft off. Its not hard put I intially had problems doing it and i've seen of others. If its not your dd than you should be fine. And like i said its not hard there are just a couple tricks you learn as you go.
J
Jwint86062
27
29 Palms, CA
May 5, 2010
  • May 5, 2010
What do you mean by dd? I have an AOD trans is it similar to the stick when changing that gear?
H
Haus
408
  • May 5, 2010
DD= Daily Driver
L
Lawbreaker5.0
543
Texas
May 5, 2010
  • May 5, 2010
dd=Daily driver. And i don't know how to change the drive gear out on an AOD. Sorry
L
Lawbreaker5.0
543
Texas
May 5, 2010
  • May 5, 2010
Dang too slow.
J
Jwint86062
27
29 Palms, CA
May 6, 2010
#10
  • May 6, 2010
  • #10
Yeah it is my dd. its ok im leaving for the USMC in a couple weeks so it wont be getting driven all the time. started up and spun around the block.
twistedwankel
200
Spring Hill, FL
May 6, 2010
#11
  • May 6, 2010
  • #11
If you have a GPS you can set it for mph. I told my old buddy to do that and he will never fix his speedo now...
J
Jwint86062
27
29 Palms, CA
May 6, 2010
#12
  • May 6, 2010
  • #12
lol! i do have a GPS but my car dosent rack up miles and i want it to. plus i want to have a working speedo. thanks for the idea i didnt even think of that. ill figure it out.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
