SPEEDO/GEAR QUESTION
  • Thread starter Thread starter dkins419
  • Start date Start date Apr 30, 2006
dkins419
187
Michigan
Apr 30, 2006
  • Apr 30, 2006
I have a 88 GT. It has the 85 speedometer and i swapped out a T-5 from a 90 GT. Now I know the 90 GT has the 140 speedo. My speedometer is off a little bit . Is it because I swapped the trans from a 90 which uses the 140 speedo? I will be getting a 140 speedometer and i am just wondering if i have to get a dfferent gear for it since I have the gear that went with my 88 or will it work fine again?
squeeeg
1,905
Michigan
May 1, 2006
  • May 1, 2006
The drive gear is the problem that you are having. You changed from a 7 tooth to an 8 tooth drive gear by swaping the tranny. You are going to have to get a new speedo gear no matter what speedometer you have(85 or 140). Here is what you are going to need:
2.73 Yellow 18 tooth gear
3.08 Black 20 tooth
3.27 Red 21 tooth
3.55 White 23 tooth
3.73 White 23 tooth
4.10 White 23 tooth(Jeep part)
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 1, 2006
  • May 1, 2006
I will have a spare stock gear from a 88 tranny soon as I put my black gear in
dkins419
187
Michigan
May 3, 2006
  • May 3, 2006
Alright so what gear will I need if I switch the speedo to the 140 with the 90 trans(or it doesnt matter which speedo just the gear)? Do i still need the 18 tooth gear? I still have a 2.73.
dkins419
187
Michigan
May 6, 2006
  • May 6, 2006
please anyone?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 6, 2006
  • May 6, 2006
do a search on "speedo gear" there is tonnes of threads with lots of info and links.
Hopefully nothing about men in speedo's comes up lol.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 6, 2006
  • May 6, 2006
alright I was felling nice
Manual Transmissions with 6 Tooth Drive Gear
Not found in OEM applications
Item Number
Description
N/A
3.08 Gear Ratio / Not possible
C0DZ-17271-A
3.27 Gear Ratio / Maroon 16 Speedo Gear
C3DZ-17271-C
3.55 Gear Ratio / White 17 Speedo Gear
C0DD-17271-B
3.73 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.90 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
4.10 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
4.30 Gear Ratio / Red 21 Speedo Gear
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Item Number
Description
C0DZ-17271-A
2.73 Gear Ratio / Maroon 16 Speedo Gear
C0DD-17271-B
3.08 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B
3.27 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A
3.55 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.73 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
Item Number
Description
C0DD-17271-B
2.73 Gear Ratio / Yellow 18 Speedo Gear
C1DZ-17271-A
3.08 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A
3.27 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393
3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Item Number
Description
D0AZ-17271-A
2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B
3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A
3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B
3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Item Number
Description
C7AZ-17271-B
2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B
3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.27 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
Now if you really want to change the internal drive gear of your manual tranny you can match it according to the table below. Be aware that the 6 tooth will offer the most combos for numerically higher gear ratios and offer the greatest degree of accuracy. The 6 tooth gear selection table for a manual tranny is the first in the page.
Item Number
Description
E3ZZ-17285-B
6 Tooth Internal Drive Gear / Black
E3ZZ-17285-A
7 Tooth Internal Drive Gear / Yellow
F0ZZ-17285-A
8 Tooth Internal Drive Gear / Green
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 6, 2006
  • May 6, 2006
from that above you have an 8 tooth drive gear and you will have to change the speedo gear to a Yellow 18 Speedo Gear
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 6, 2006
  • May 6, 2006
I think that's right you situation has me confused lol (tired)
dkins419
187
Michigan
May 6, 2006
#10
  • May 6, 2006
  • #10
lol thank you for the help, but i got 1 last question. Does it matter if you have a 85 or 140 spedometer?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 7, 2006
#11
  • May 7, 2006
  • #11
shouldn't
blue302stang
61
#12
  • May 7, 2006
  • #12
The Gauge cluster should be calibrated to the 85mph so it should work fine with the tranny
_jb_
808
Michigan, Berrien County
May 7, 2006
#13
  • May 7, 2006
  • #13
Nope, I switched mine and it worked perfect.
trbkrb
1,976
Houston, TX
May 7, 2006
#14
  • May 7, 2006
  • #14
As long as a speedometer is stock and has not been altered or recalibrated for some reason, it does not matter what one you use, they will read the same speed. They all calculate the speed by the number of turns of the cable, and 85 or 140 speedos count the same number of turns at every given speed.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
