Speedo problems...
  • Thread starter Thread starter my289eatsrice
  • Start date Start date Dec 27, 2005
M
my289eatsrice
121
Woodstock, CT
Dec 27, 2005
  • Dec 27, 2005
Alright, I have the classic "bouncing" speedo problem, where the speedometer jumps up and down extremely fast. So, i took the natural route and replaced the speedometer cable and lubed it up very well. Now, my speedometer does the same thing, but only under around 50 mph, over that speed it works flawlessly...I dont understand. I don't think it's my VSS because my cruise control also works perfectly, but I dont know what else it could be? Help? Thanks...
Euphoric306
905
  • Dec 27, 2005
speedo magnets might be going out, but it would likely bounce at higher speeds if that were the case
5.0 Nostalgia
904
CT
Dec 27, 2005
  • Dec 27, 2005
What about the speedometer gear? Mine did that and I pulled it out to find that there was only two teeth on it.
M
my289eatsrice
121
Woodstock, CT
Dec 27, 2005
  • Dec 27, 2005
Yes, but why would it only bounce under 50 mph? I pulled the VSS out and looked at the gear that presses on to it and that looks perfectly fine w/ no wear marks, is there another gear inside the tranny other than that one? Also, could it be that the actual speedo cluster is sticking under 50 mph, but over that speed its spinning fast enough so that it doesn't stick? I'm not to sure what it could be...
D
DuffManRHA
15
San Marcos, CA
Dec 27, 2005
  • Dec 27, 2005
mine boucnes when under 25 mph, no big
you can try removing the cable (PITA from the cluster, easy from the trans) and lube it real good with some white lithium or some light wheel bearing grease
Eric
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
Y
2012 GT/CS Electrical Problems
  • Yomster
  • Dec 2, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 2, 2025
Bullitt347
