Speedometer cable leak
  • Thread starter Thread starter Joey7508
  • Start date Start date Feb 25, 2008
J
Joey7508
198
Kerrville TX
Feb 25, 2008
  • Feb 25, 2008
So here it is I am leaking fluid from the cable where the silver end piece is crimped, the one that would go into the vss. I put a new vss in hopes it would help, but it is clearly the cable now. Here is the deal I have a viper t56 and I was going to get a new cable form d&d but the guy I talked to said it should not leak out cable that there shoudn't be trans fluid pushed in the cable unless the vent tube is pinched or plugged. But from what I have been reading on here fluid does go in the cable form the trans. Has anyone solved this type of problem just by putting a new speedocable on? The trans and cable are only a year old with maybe 6,000 miles on them Don't know that it makes any difference.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 26, 2008
  • Feb 26, 2008
transmission fluid doesnt go into your cable through the trans. it is seperate. but our cables do have a type of grease in them. you might have a crack or split in the cable housing and its allowing water in.
Silvers
51
  • Feb 26, 2008
I think that is where mine is leaking too but I have a T5. Is there an O ring where the cable enters the VSS?
F
facemelter71
60
cincy
Feb 27, 2008
  • Feb 27, 2008
The VSS has an O-ring on it to seal the tranny fluid in.THE CABLE DOES NOT SEE TRANNY FLUID.AT ALL.
87coupe50
105
WAYNESBORO, PA
Mar 6, 2008
  • Mar 6, 2008
after taking my car to the track I noticed I'm having the same problem . Anyone have a fix?
Could also be because I've been doing a lot of work down there trying to fix a reoccuring broken speedo cable, kept snapping at the sharp bend at the trans mount. On the third attempt I replaced the entire cable with one for non-cruise and took out the VSS (never had cruise anyways) and it's still leaking out the hole. New non cruise cable didn't come with new o ring so I used the one from the VSS. Maybe I just need a new O ring. Good news is: the speedo is working and I now have the right speedo gear.
1990FoxLX
Kennesaw, GA
May 17, 2009
  • May 17, 2009
I have this same annoying problem. I never had the problem with my T-5. But when I swapped in the T56 from D&D, the longer (cheaper) speedo cable started laeking at the crimp. I assumed the VSS was to blame and I replaced it. Tranny fluid started leaking again within a few days. How can a brand new VSS have this problem?
I don't know what to do next. Doesn't make sense to replace the VSS again. I thought about just sealing up the crimp area of the speedo cable with silicone and then just let tranny fluid enter and stay in the cable, but I fear that tranny fluid will start leak at the back of the speedometer.
I never had this issue with the T-5. Why should the T-56 make a difference?
HELP ANYONE!?!?!?
4G-KDMP
935
CA
May 17, 2009
  • May 17, 2009
There should be 2 rubber O-rings.
1 o-ring around the VSS to seal it between the VSS and the trans housing.
1 o-ring around the speedo cable to seal the cable in the VSS.
1990FoxLX
Kennesaw, GA
May 17, 2009
  • May 17, 2009
Yep, both O-rings are present and accounted for. The leak occurs right at the crimp. But, I have a theory about why I have this issue on the T56 and didn't on the T5.
The speedometer drive hole on the T5 was on the left side and above the tail shaft centerline, well above the fluid level line. The speedometer drive hole on the T56 is on the right side and below the tailshaft centerline, very close to the fluid level line. While driving, inertia wouldsubmerge the VSS in transmission fluid.
My theory is that the Ford VSS is intended to keep splash oil from exiting the transmission. However when the VSS is exposed and ran while submerged in transmission fluid, it might not have the ability to maintain a seal and fluid might leak past.
This is my theory. I would love to have some experienced Ford folks tell me if this is reasonable or if I am off my rocker.
4G-KDMP
935
CA
May 17, 2009
  • May 17, 2009
I don't think you're off your rocker your theory makes perfect since to me.
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Sep 29, 2009
#10
  • Sep 29, 2009
  • #10
Bump.
I have this same problem. 500 miles on a brand new VSS and a new cable and it leaks fluid where the cable plugs into the VSS. I'm leaking quite a bit now...more and more the more i drive.
So there's an O-ring internal to the VSS? I'll have to pull it off and replace it then.
J
Joey7508
198
Kerrville TX
Sep 29, 2009
#11
  • Sep 29, 2009
  • #11
be a while I did solve this problem on mine. There is an o ring in the vss. On another car I had fluid coming all the way up the cable even with the o ring in place and the problem there was that a auto speedo gear had been cut on the little post on the end to fit, and that made a hole in the end of the gear where it is normaly solid. Put an oring in my vss and fixed it and put the correct manual speedo gear on that one and fixed it.
J
Joey7508
198
Kerrville TX
Sep 29, 2009
#12
  • Sep 29, 2009
  • #12
the O ring fits right on the silver end ov the cable and just sort of fits down in the vss sould be able to see it if you look in the vss with the cable off.
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Sep 30, 2009
#13
  • Sep 30, 2009
  • #13
Okay, swapped out the O-ring. LEts see if it fixes it. Original Oring was coated orange, but it was flaking off and deteriorating. I swapped a new Viton O-ring on.
BTW, O-ring on a T-5 VSS for the cable to VSS connection is a -110 O-ring.
I do think however my cable leaks where the metal end is crimped to the plastic sheath. Damn cheap LRS cable! I might have to clean it up really well and smear silicone around this connection.
M
mkk50
109
29
39
Oct 1, 2009
#14
  • Oct 1, 2009
  • #14
I had problems with my replacement cables leaking/snapping, i went through three of them over a couple years. I bought a used OEM cable, and have had no leaks or speedometer bounce or snappage, I think I measured the metal end on the ford cable, and it was slightly thicker than the replacements, but I cannot remember for sure anymore. I also have a ford vss.
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Oct 1, 2009
#15
  • Oct 1, 2009
  • #15
Well i think i may have fixed it. I ended up putting a small peice of heat shrink over the metal head of the cable where it comes out of the VSS. The shrink has a small bit of glue inside so it should seal that up well.
Now yo see if the new o-ring seals as well.
I have to say i'm disappointed with the quality of some of the parts LRS sells. I've ordered a few things from there, and they just are cheap and flimsy compared to OEM stuff
Reactions: nicholase
M
mkk50
109
29
39
Oct 1, 2009
#16
  • Oct 1, 2009
  • #16
I would have to agree with you, i bought a replacement cover for the stock instrument panel, and it was too big and didnt even come close to fitting. I had gotten my speedometer cables from them, and was un-impressed. I got a full carpet kit, and the main interior carpet is great, but the hatch carpet is too big, and if I trim it, I will loose the stripping that is on the edges. I think it is more aftermarket parts in general, and not just LRS.
J
Joey7508
198
Kerrville TX
Oct 1, 2009
#17
  • Oct 1, 2009
  • #17
Just check after you have driven it a while and make sure that it doesn't pust fluid up the cable and leak behind the dash. You will know because it will drip on the gas pedal. Thats what happened on the car with the bad speedo gear. My cable that leaked at the silver fitting was a cheap cable as well that came with my viper kit. The d&d stuff is really good just the cable is kinda cheap. Probably made by who ever makes lrs stuff. With the vss all sealed up you shouldn't get trans fluid in the cable any way. It comes with some kinda grease or oil in it, they sale some at the parts store in little tubes.
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Oct 1, 2009
#18
  • Oct 1, 2009
  • #18
Yeah, some of that lube came with the cable. I shoved as much of it up the cable as i possibly could.
Victor's GT
44
New Jersey
Dec 29, 2014
#19
  • Dec 29, 2014
  • #19
OLD THREAD - I do believe your theory to be correct as well when using a T56 with mechanical speedometer/VSS provision which is on the passenger side of the transmission. Mine is a D&D Viper spec T56. A good amount of fluid makes it's way into the speedometer cable and will leak out if not sealed at the crimp
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
