I think the leak that was leaking off the crossmember might be from the speedometer gear i think its called. Can someone show me a pic of exactly where it is and also how do i change the seal and everything?
Take the bolt out that holds the gear and assembly in place slide the assembly upward (you might need to twist it some) and you'll be left with this in your hands. View attachment 447553
Replace the O-ring and reverse the procedure.
You'll probable need to wiggle or twist the assembly to get the plastic gear to seat if it doesn't go all the way in.
