Speedometer Problems.....150mph in 2nd GEAR!!!!!!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
So I just got the car back together and running, drove it to the exhaust shop and the speedometer is like 4 times as fast as it should be. I didnt mess with the tranny at all....just unplugged the harness and plugged it back in when the tranny was back in. Its a TKO600 and i have a 3.73 in the back. Never had this problem before. Any ideas?:SNSign:
You could have a friend safely take pictures. Having the speedo pegged will be something to show the grandkids (who will be in flying cars by then). :D
If you are at like 12k RPM this is OK... If not clean everything but I can't see why a bad connection would cause it to read fast...
Unless you are using the brothers speedcal maybe?
Hey JT
If Nate can go 150 in second gear :crazy:
Does that mean :scratch:
225 in 3th :)
and
300 in 4th :nice:
and
as that guy on the radio says
"Ludicrous Speed" in 5th :banana:
Seriously Nate :D
Can you provide more info on what all you have done lately that might
have caused that to happen?
Grady
the newer TKO 500/600 use the electronic speed sensor correct? they are setup for the 99+ cars where its pretty much a direct swap in.
im not sure if you can swap install a VSS thats gear driven like our cars are or not. call dallas mustang and find out. you might need a speed cal to adjust it back down
the TKO 600 has a provision for the little speedo gear. Right now I'm using the stock speedo gear and stock gears (3.08) and it actually reads 5-15 mph lower than true speed. Something else has to be screwy.
First off, thanks guys :nice:.
About a month ago before my oil pressure problems everything was fine. I changed nothing on the tranny or anything that might have something to do with the speedo. My gear is the right one that matches the 3.73's. All i did was unplug it drop the tranny, drop the tranny and motor back in, and plug it back up. Not sure what can cause it....guess i'll start with cleaning it :shrug:
Wes, I don't wanna know what happened to your speedo :p It's a good look (though taking a pic at redline would be best). :D
Have you guys been holding back? I was thinking along the same lines as Grady. Many have 3.73:1 gears but you guys have like 0.73:1 gears.
Nate, If not mentioned, I'd just call D&D [in Wixom] or Hanlon and see what they think. They probably have a real good idea in about 2 seconds of what to check.
Good luck.
Man, that is all that power I've got! Ya'll guys with T5's just don't know.
Seriously though, I think my SpeedCal is grounding out somewhere - the speedo only goes screwy about once a week. I'll look at it next weekend - we're doing a Trickflow H/C/I install and Longtube install on sage2k's car at my place this weekend.
Wes
Wes
Sounds good. If you think of it, post up if the Speedcal was the issue (you'll save future searchers :nice: ).
It seems like you and Sage are always working on something. Must be nice. :drool:
Nate, let us know how it goes. :nice:
I sure will make an updated post - not sure when it'll be - the S-trim is killing me just sitting in my shop. Plus sage will be talking crap to me now that his Trickflow kit is in so a track visit is imminent. :)
Wes
