speedometer q's
  • Thread starter Thread starter TOOLOW91
  • Start date Start date Jan 10, 2009
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 10, 2009
  • Jan 10, 2009
ok so i got tired of searching so i figured ill just post it .. my speedo always jumped a bit since i got my car .. it has the stock aod , stock gears-so no problems there... about i week ago coming out of work i was doing about 20 mph it flopped around to about 140 and flopped back.. didnt really care laughed about it . well last night on my way back to staten island from broken my speedo jus crapped out.. now i need to no does the gear inside the gauge come out or does just the cable thread in and maybe the cables bad? lmk what you guys think
O
One91Fox
28
Decatur, AL/Starkville, MS
Jan 10, 2009
  • Jan 10, 2009
I had a loose cable that made my speedo jumpy but not quit to the extreme as you say. I just had a local shop replace it and the speedo is fine now. You shouldn't have to change the gear or anything if its a stock trans and rear gears.
drummerboy5.0
18
  • Jan 10, 2009
I had that same problem.
on the side of the transmission where the speedo cable is attached there is a U shaped bracket that holds it in place. that bracket worked it's way loose and the gauge started jumping around and eventually quit. I ended up loosing the bracket somewhere so I got it up on the hoist and made myself a sling out of zap-straps which held the cable in place until I found another bracket. worked like a charm.
with respect to your other question, the gear is on the tranny side. the cable just screws into the back of your gauge cluster.
My cable just broke because it somehow touched the new headers i installed and melted.
It's not too hard to replace..
just pull the cluster, and the cable threads through the firewall through a little rubber grommet. there are a few metal clips that hold it in place along the undercarriage until you get to the tranny where it is really just plug and play.
you will have to move the plastic gear over from the old cable however, cause most new speedo cables don't come with gears.
the repro cables are fairly cheap so I would say try replacing it anyways just to fix the floating gauge problem.
And unless you have cash to burn, don't take it to a shop. If you have a pair of jackstands It can be done in the driveway in about an hour.
My car has the manual trans, so it might be a little different. I'm just saying what worked for me. Shouldn't be much different though because it's just a speedo cable.
Hope that helps dude
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 10, 2009
  • Jan 10, 2009
thanks for the detailed reply . i would deffinitly tackle it myself as i work for a body shop putting cars back together . im just new to this whole mustang thing and i no this is a common issue on them but i wanted to diagnose before i just started changing parts
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 10, 2009
  • Jan 10, 2009
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Speedo head cable clip
Photo courtesy of Almost Stock
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
