Speedometer replacement
  • Thread starter Thread starter 89OctaneStang
  • Start date Start date Sep 2, 2007
89OctaneStang
12
Ft Lewis, WA
Sep 2, 2007
  • Sep 2, 2007
Well, I just replaced my 85 MPH speedo with a 140 MPH speedo. But now I'm having problems getting it to read right. I changed my original 18 tooth gear set to a 23 tooth gear set and it didn't fix the problem. And when I took the 23 tooth gear out today, the gear teeth had been broken while inside the trany during that short period of time. Has anyone worked on their speedo before and experienced something similar to this and found the fix to the problem? Cause I'm clueless at this point....
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Sep 2, 2007
  • Sep 2, 2007
You DO NOT replace the speedometer gear when changing the speedometer. The speedometer gear is only changed when changing the rear end gear ratio or tire size. Put the original gear back in.
Killer50stang
632
  • Sep 2, 2007
Just what I was thinking....all it is is a backplate...it should just work...but keep in mind it reads different.
89OctaneStang
12
Ft Lewis, WA
Sep 2, 2007
  • Sep 2, 2007
I didn't change the speedo gear right away. I only changed it after I went down the road for a test drive to see how the new speedo worked and it was telling me I was doing 130MPH when I was actually doing about 45 MPH. If it isnt the gear set then what would cause that? The 85 MPH guage worked perfectly before I put in the 140 MPH guage.
TRWXXA
190
Sep 3, 2007
  • Sep 3, 2007
That shouldn't happen. The 85 mph, 140 mph, and 160 mph speedometers all work on the same standard input -- 1000 rpm/mile. Swapping one speedometer for another is all you have to do.
Is your 140 mph speedo a new unit, or a used one? It's possible that it's broken, or had the 85 mph instrument face changed to a 140 mph face. There is no speedo gear that can correct that much error by itself.
89OctaneStang
12
Ft Lewis, WA
Sep 3, 2007
  • Sep 3, 2007
No, it was a used unit. So I guess that unit is broken then. Thanks for the input....
TRWXXA
190
Sep 3, 2007
  • Sep 3, 2007
Ouch! I hope you didn't pay too much for it.
You could take it to a speedometer show and see if they can fix it. But it would probably cost as much as getting a new unit. I suggest just biting the bullet and getting a new speedo -- $160 to $180, from Latemodel Restoration Supply. It just seems that with used mechanical parts you always wind up buying two, just to get one that works.
89OctaneStang
12
Ft Lewis, WA
Sep 3, 2007
  • Sep 3, 2007
I see that...
cenok is family
1,409
69
79
Norman, Ok
Sep 3, 2007
  • Sep 3, 2007
did you replace the whole instrument cluster or just the speedo itself?
89OctaneStang
12
Ft Lewis, WA
Sep 3, 2007
#10
  • Sep 3, 2007
  • #10
Just the speedo
89OctaneStang
12
Ft Lewis, WA
Sep 3, 2007
#11
  • Sep 3, 2007
  • #11
The used speedo I got didnt have the little black cap that goes on the needle. When we attempted to use the black cap off of a tachometer that wasnt being used it would read funny because the cap had a little weight in the back of it. Could the speedometer be messed up cause of the little black cap being gone?? If anyone has one laying around, do me a favor and pull off the black cap on the needle and look to see if there is a little chunk of mettle in it, please....
TRWXXA
190
Sep 3, 2007
#12
  • Sep 3, 2007
  • #12
It's possible. The speedometer is a pretty sensitive instrument -- only driven by a small magnetic field and a light spring. Changing the balance of the needle could throw it off quite a bit.
Sorry I don't have a speedometer around to check on that cap.
cenok is family
1,409
69
79
Norman, Ok
Sep 3, 2007
#13
  • Sep 3, 2007
  • #13
i got an old 85mph speedo i can check the cap on that, dunno if it's the same though. i just did the same thing to my car a couple weeks back. had to do a **** load of trimming to get it to lay in the cluster flush, but all the mechanicals work perfect without changing anything.
89OctaneStang
12
Ft Lewis, WA
Sep 3, 2007
#14
  • Sep 3, 2007
  • #14
Well I fortunately didnt have to do any trimming to get it to fit but I am having trouble getting it to read right. I just went to the guys house that I bought the 140 from and picked up my old 85. I checked the back of the needle and sure enough, it has a small little piece of metal or magnet in it. So, after work tomorrow, I'm going to tear apart my dash again and get the 140 out and put on the needle from the 85. I hope that the MPH isnt gaged by the specific weight of the needle. But I will have an answer for everyone very soon.
The next thing I'm working on is my rear differential traction lock clutch that is burned out. Anyone have any experience with this???
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
