Why?abusedstang said:I would kill for that problem!!!
checked all the fuses they were good to go......_MATiC said:check your fuses..i remember i blew one of mine and the odometer stopped working until i replaced it..which one, i dont remember..
Green 94 5.0 said:there is a plastic gear in the cluster that breaks over time, quite the same as the speedo gear in the tranny. it has happened to quite a few people i know.
Yah, any of those should be fine for the purpose of cannibalizing odo parts. Actually the cheapest would be a V6 cluster. I would only get a Cobra cluster to swap out entirely (which is actually what I did on my GT -- bought a 40k mile '95 cobra cluster and swapped odo's from the GT).V8SHME8 said:I have the same problem as you, I was going to get a cluster off ebay. The only question I have is what year clusters can I use. I would assume 94-98gt or cobra would be fine can someone verify this?
I guess that would explain why my speedo doesnt move untill I tap on it then it moves all the way to 100 mph and back down?Green 94 5.0 said:there is a plastic gear in the cluster that breaks over time, quite the same as the speedo gear in the tranny. it has happened to quite a few people i know.
