speedomter 'corrections'
If you're running an automatic transmission, you'll need either a 21 or 23 tooth driven gear. The drive gear is cut into the output shaft and can't be changed. If it's a manual, then it will have a plastic drive gear that will give more choices for picking the driven gear. Go to Mustangs Unlimited's site for gears and the calculator.
