spindle questions
  • Thread starter Thread starter HarleyFordFan
  • Start date Start date Apr 25, 2004
HarleyFordFan
239
  • Apr 25, 2004
are 94-97 spindles the same? also what is the install procedure instructions for bolting them onto my 88 gt? is it bolt on or do i need to modify someting? please help me out here...Thanx in advance.
HarleyFordFan
239
  • Apr 25, 2004
TTT please help...
HarleyFordFan
239
  • Apr 26, 2004
bump please help....
MrKwik
1,008
Kansas City, Kansas
Apr 26, 2004
  • Apr 26, 2004
You want to get the 94-95 setup if you can find them. The later ones make the track wider and can give you tire clearance issues. I have not done it myself but I think you need a spacer of some sort on the lower ball joint and I think I heard that you need an adaptor for the brake line and maybe relocate it, but I dont swear to that.
TT91
1,536
Paramus, NJ
Apr 26, 2004
  • Apr 26, 2004
The 97 spindles look the same, but have an 8mm difference. Ideally you want to use sn-95 spindles up front. They will bolt right on, but you’ll need some washers to stack on top of the ball joints to line the cotter pin hole up on both sides. You need 5 lug rotors, which means 5lug rims…U may need different brake lines as well, I’m no sure about those
HarleyFordFan
239
  • Apr 26, 2004
so i cant use (1) 97 spindle and (1) 94 spindle. ok thats l;ogical because of the track width. you see i am purchasing a set of front brakes off of 97 gt and the passenger side spindle has a slight tweak on the steering arm or something. so if i could not straighten it out i was gonna go to the local yard and get one out of a 94 they got sitting there.
TT91
1,536
Paramus, NJ
Apr 26, 2004
  • Apr 26, 2004
The “steering arm”(or tie rod) shouldn’t matter since your supposed to use the one on your 88. Use the 94 or 95 spindles and your wont have any problems. Be sure to find out about those brake lines, im still ?? about that.
trbkrb
1,976
Houston, TX
Apr 26, 2004
  • Apr 26, 2004
Read http://svo73mm.cjb.net and Matt answers all of your questions. As far as the 96 up, the steering arms on the spindles are straight on them, and the 94-95 the arms are bent, so you have a difference in the two arms besides the width. You can use the SN95 lines, but you will probably have to use an adapter for the passenger side since the SN95 hose is smaller than the Fox on that side.
If it were me, I would get both spindles from the 94 if you can, and then get the 99+ PBR dual piston calipers.....much better than the 94-97 calipers and not too expensive. We have them locally for $25 each. Look on www.car-part.com and maybe you can find some. Matt has the install info and the slight grinding info needed to install the PBRs on the 94-95 spindles.
Good luck!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
