spindles questions and horror story
blackstangt
460
ny
where can i get one and how do i know if a used one is good or not? I went to mavis for a tire plug, they torqued down the lugs includiong the locking lug. They torqued all the lugs down so much, i had to use a jack and jump on the other end of a four way on the regular lug nuts, the key for the lock nuts stripped out and i was unable to do those wheel bearings. weeks later, after just getting the phone # from ford for a new key, i started hearing a little bit of vibration, but I couldn't get the lug off and barely made it home one day. the wheel bearings had ground to **** and I had to get a friend to grind the lug flat on one side to get it off. now, when i changed the wheel bearings, there is play in the wheel after i bring it back after a mile of driving. so i'm not driving it, and the spindle probably need to be changed. how do i know if a used spindle is good? also, where can i get a new one cheap, and is this the problem? lesson learned, no one touches my car.
