Fuel Spits sputter pops and bangs under load. Help wanted
  • Thread starter Thread starter sickntired
  • Start date Start date Mar 23, 2024
First Prev 2 of 2
sickntired
14
Dallas
Mar 31, 2024
#21
  • Mar 31, 2024
  • #21
Potomus Pete said:
The car did run really good for a day or two right. If so how good? Smooth power.
Yes it ran extremely well. Plenty of power and pretty smooth there where no drivability issues everything seemed fine.
manicmechanic007
5 Year Member
Sep 26, 2017
2,559
726
143
Roy, Utah
Apr 1, 2024
#22
  • Apr 1, 2024
  • #22
A couple of checks to get you thinking
Base engine.
The roller block and your OEM distributor gears match?
Verify that, and also actually check the degrees of crank rotation before the distributor rotor turns (each way)
Check the base timing again, verify 10 BTDC with the spout out
Install a noid light in each injector and test the processor ground signal signal throughout the full rpm range
You should get just about a steady looking noid light at WOT
Manually fire each injector while monitoring the fuel pressure drop
sickntired
14
Dallas
Apr 1, 2024
#23
  • Apr 1, 2024
  • #23
Base engine.
I will look into those things mentioned however i dont think the distributor gear compatibility is at play here. The car seems to run fine free idle it will rev seemingly fine... its when its under anyload that the symptoms come out. Also the aftermarket cam was transplanted from the original roller block into the current explorer block so there shouldnt be any issues with distributor and the cam distributor drive gear matching up i would think. Also it ran fine for a couple of days i would presume any non compatibility here would prevent it from running fine at all and also be unable to set timing as the distributor and the rotating assembly wil not be in sync. Im no mechanic and so if my reasoning is off please explain. I will get some noid lights and check injector pulse to see if that shows anything that seems more likely at this point. But without being able to graph injector pulse i dont know how i will ne able to detect any issue please explain. I triple checked the timing and set it at 14 degrees but will go back and reconfirm. Lastly i want to thank everyone for taking the time to try and assist me with this.
First Prev 2 of 2
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
